Spring rates for KW clubsport, changing rates
Okay, so the stock rates for the KW Clubsports are 855lbs/in front and 455lbs/in rear. I called KW for more info and they said the dampers could adjust to support springs ranging from 555-1155lbs/in in the front and 155-755lbs/in in the rear.
Is anyone here running different rates on KW Clubsports here? The reason I ask is because that front spring rate seems really high to me, and I will be running SPL midlink so I will need to buy springs for the rear anyway. Just trying to get some info from the experts, I'll be running Hankook R-S3's in 275 or 285 all around and a weight of around 3350 with me in the car. Was thinking somewhere around 616lbs/in front (11kg/mm) and 504lbs/in rear (9kg/mm) as a starting point. Any input is greatly appreciated. |
Originally Posted by SoCal07HR
(Post 9405525)
I would probably look into Nismo T2 spring rates, IMO they are a good place to start.
why are you looking to change something you haven't used yet?
you can't use SPL midlinks with Clubsports either btw, as Clubsports are only now offered as a true rear coil design |
Originally Posted by Z1 Performance
(Post 9424204)
you can't use SPL midlinks with Clubsports either btw, as Clubsports are only now offered as a true rear coil design PM me price of the clubsport in a true coilover rear you get a set I'll buy it. |
(Post 9424001)
Z1, any response? You get a set of those clubsports that you were talking about and I'll buy them. Every sponsor I've contacted about them and even KW themselves said the clubsports are OEM style rear. You say they are now only offered in true coil, show me.
sorry, didn't mean the clubsports, got those confused with their next tier up units
that spring rate spread is beyond retarded fwiw, you're right - 11/9 should be a decent spread, will be largely dictated by your driving style and what those tires can deal with (never used them myself) |
(Post 9427614)
sorry to bump an old thread but i am in the same place with my build. with the mid link in the rear. an the kw smaller springs.
Originally Posted by joshua350z6841
(Post 10319520)
kw clubsport the rear still use the oem setup an with the kw springs are to small for the spl rear toe midlink
