which seat base? sparco or planted tech for sparco circuit seats?
Sparco circuit seats.
Planted or sparco? cost is very similar. Plus sparco has an option for LOW and TALL seat bases? I'm 5'6" and do not want to sit any lower than current OEM level. I'll be using sparco sliders and side mounts. Thanks. ap |
I can vouch for the planted being quality, and theyll put you at a good height which wont be too low, though at your height you may be a candidate for the TALL brackets from Sparco. Though I would think you could make up the height via the mounting holes on the side mounts.
The planted has multiple holes drilled for adapting to sliders and side mounts, whereas the Sparcos only have two positions per side...in my case I used the OMP side mounts (no sliders, fixed mounted) and had to drill an extra hole to position them as far aft as possible. Something to think about when using mismatched hardware. |
Be forewarned on the planted passenger side bracket. If you plan to use the passenger side seat bracket from planted your passenger's head will be in the headliner. It sits super high.
^ Same with a Sparco on the passenger side for manual tranny. I tried both hoping one would be lower than the other.
I have planted, I am 5.10 and it was too tall for me. Had to mod them. But they are made very well and fit perfectly.
I also have Planted with sliders and seat from OMP. I am also 5'6, fits me perfect. And yes the Planted seat base is good quality.
I'm 5'9", planted was too tall for me to use with OMP TRS, I had to modify. The passenger side is way too high. If you search here I have a thread that includes detail on the Planted bases for both sides and how I modified them to work for me.
Originally Posted by 2000atlanticgt
(Post 10686349)
ap |
