Body Exterior Body kits, grills, HID kits, etc.
Nissan 350Z Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day
Old 10-27-2015, 06:51 AM
Diode Dynamics
Vendor - Former Vendor
Diode Dynamics's Avatar
Lightbulb Nissan 350Z Reverse/Backup LED Bulbs! Plug & Play Install! Ships Same-Day
Nissan 350Z Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different levels of brightness for your reverse light or backup light bulb (7440/3 size). We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Your purchase includes two 7440/3-sized LED bulb, for perfect fitment in all Nissan 350Z Models.
Bulb Design
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Fitment. All three bulbs use a quality inject-molded 7440 terminal, with a locking base connector and proper pin alignment, designed for exact replacement of your factory 7440 bulb.
Included in your order is TWO BULBS.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP11: (310 lumens). Slightly higher brightness than OEM bulbs.
XP80: (510 lumens). Much brighter than OEM bulbs. These are bright!
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction. Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
Diode Dynamics is offline
Old 11-06-2015, 05:48 AM
CStan_Z33
CStan_Z33's Avatar
I really want these... I will definitely be placing an order after SEMA is over! I have recently (in March I believe) purchased the footwell lighting kit, dome light kits, the trunk light, and the license plate lights; However they stopped working :/ Aside from the license plate lights, everything else works fantastic! I vouch for Diode Dynamics and will continue to make many more purchases!
Christian
CStan_Z33 is offline
Diode Dynamics (11-09-2015)
Old 11-09-2015, 01:12 PM
Diode Dynamics
Christian
Thank you for your support Christian!
If you purchased your license plate lights from us, please contact our customer service team: (314) 205-3033, they should still be covered under warranty
Nick C.
Old 04-13-2016, 03:29 PM
slmdchvy05
slmdchvy05's Avatar
I would have gotten these if I had seen them sooner, I just put on a HID kit for my reverse lights
slmdchvy05 is offline
Old 04-14-2016, 04:43 AM
Diode Dynamics
Yikes, I'd be careful with HID for reverse light locations. That's going to produce significantly more heat than your factory incandescent bulbs.
In addition, HID has to warm up to achieve full brightness, so you'll want to keep that in mind when backing up in the city or populated streets.
Should be plenty bright though!
Nick C.
Old 04-18-2016, 03:10 PM
pfregeolle
pfregeolle's Avatar
do you guys offer these back-up/reverse LED bulbs in continuous strobe?
pfregeolle is offline
Old 04-19-2016, 06:24 AM
Diode Dynamics
We do not offer a reverse light LED with any strobe features or functionality. You could add something like that, but you'll want to check with local laws on the legality of such a thing.
Nick C.
Old 08-05-2016, 07:13 AM
Diode Dynamics
Follow Us On Facebook | Diode Dynamics Timeline
Old 08-08-2016, 03:58 PM
Diode Dynamics
Diode Dynamics Dealer Locator Tool
Old 08-09-2016, 12:18 PM
Diode Dynamics
Old 08-10-2016, 10:16 AM
Diode Dynamics
Don't forget to send us a PM for the free-shipping code!
(U.S. members only)
Thank you,
Nick C.
Old 08-11-2016, 07:40 AM
Diode Dynamics
Feel free to contact us if you have any lighting related questions!
(314) 205-3033
Nick C.
Old 08-12-2016, 06:13 AM
Diode Dynamics
Chat with an expert on our site!
Diode Dynamics Website
Old 08-15-2016, 02:19 PM
Diode Dynamics
Old 08-16-2016, 11:48 AM
Diode Dynamics
Looking for a Diode Dynamics' Authorized dealer near you? We've recently added new dealers to our map!
Dealer Locator Tool
Old 08-17-2016, 02:48 PM
Diode Dynamics
Old 08-18-2016, 06:55 AM
Diode Dynamics
PM Responses sent!
Thanks,
Nick C.
Old 08-19-2016, 05:59 AM
Diode Dynamics
Old 08-22-2016, 03:43 PM
Diode Dynamics
PM Responses sent!
Thanks,
Nick C.
Old 08-24-2016, 12:52 PM
Diode Dynamics
www.diodedynamics.com
