DIY: RPF1 Center Caps
So for those have Enkei rpf1's, you know that the price for their center caps is a little steep. And they look very cheap and IMHO they dont do the wheels justice at all. I did some research on the web to find some cheaper caps that fit, and a good way to color match them to the enkei black. They look much better than the enkei caps to me.
Here is what you need: Four Honda 44732S9AA000 center caps ($15 on ebay) 200-600 grit sandpaper Rustoleum Satin black exterior spray paint I was able to find these center caps on ebay for $14 shipped used. It doesn't really matter if they are used and beat up cause you will be sanding them down and re-painting them anyways. First, give the faces of the center caps a good sanding to remove the paint thats on them. I would suggest around 300-400 grit sandpaper: http://i10.photobucket.com/albums/a1...bdjj/caps1.jpg Then give them some of the rustoleum black spray paint. Do a heavy first coat with this paint. And let t dry overnight: http://i10.photobucket.com/albums/a1...bdjj/caps4.jpg The next day you will want to wet sand them. I used 500 grit wetsand on these and it turned out pretty smooth: http://i10.photobucket.com/albums/a1...bdjj/caps3.jpg Then dry them off thoroughly and spray another coat of black paint. You may need a couple of coats depending on your wet sanding skills. I did a couple of final coats and ended up with a factory looking finish: http://i10.photobucket.com/albums/a1...bdjj/caps5.jpg Then just push them into the hole in your wheels, they should fit pretty snug. No need to secure them in any other way. done :icon21: http://i10.photobucket.com/albums/a1...bdjj/caps6.jpg Total cost is about $25 for everything including paint. |
Nice find!
Thanks man, I believe I have a couple of sets from my Honda days. Gotta go dig in the garage now.
AWESOME!!! Thanks
Chris |
Wow those turned out awesome. How did you think to use the Honda center caps?
Win
Originally Posted by VMRWheels
(Post 10021475)
And thanks guys I'll get some better pics here in a sec |
Nice job OP!
Originally Posted by Esser
(Post 10021526)
Cause i saw honda guys running their honda center caps on their RPF1's lol
