2007 350Z convertible outside door handle removal
How do you remove the door handle on a convertible 350z? I only see one rubber grommet. The 350Z coupe has two rubber grommets with 10 mm bolts behind them, the convertible has one. Please help!!
350z very doorhandle removal and replacement
Have you fixed the door handle yet. I'm in the process of replacing the drives side door handle.
Originally Posted by NAVAIR JUNKIE
(Post 10988109)
2 10mm bolts and its out |
Originally Posted by travlee
(Post 10988150)
He hasnt logged in for 10 months
Yes, you need to remove the door guide pin. If memory serves right, it's held in with 3 torx screws.
Make sure you use a 10mm magnetic nut setter to avoid dropping the bolts into the door. |
painters tape in the socket works in a pinch also
One bolt is already at the bottom of my door.. will try the painters tape since there are not any stores near me that carry magnetic nutt setters...
GOHeels!!! I'm tried and true I blead Carolina Blue |
(Post 10988287)
Torx
(Post 10988201)
Make sure you use a 10mm magnetic nut setter to avoid dropping the bolts into the door. what size are the 3 torx screws? |
Originally Posted by Toons
(Post 11036994)
I need same info. All videos show the coupe versions. I think need to remove 3 torx screws holding alignment pin to get to upper handle mount bolt. Can anyone verify?
Originally Posted by PcolaZowner
(Post 11079589)
