DIY: Custom Cup Holder for 2003-2005 350Z
One of my biggest complaints with my '03 Z is the lack of an appropriately placed cup holder.
The passenger "slide-out" one is flimsy and poorly located for the driver. The center console location is too far rear. One solution is to replace your '03 - '05 center console with a newer one as shown here: https://my350z.com/forum/body-interi...sole-swap.html This works great and has the cleanest look, but has the disadvantage of being relatively expensive, depending on how cheaply you can get the trim pieces you'll need. Here is my solution: https://cimg2.ibsrv.net/gimg/my350z....f050da7855.jpg Finished product. The corners from the ash tray show, but you could fill it with body-filler and texture it / paint it for cleaner look. https://cimg0.ibsrv.net/gimg/my350z....2cadf53fb4.jpg cupholdersplus.com has several different aluminum cup holder inserts with different colors / finishes to match your Z. https://cimg3.ibsrv.net/gimg/my350z....847b11c565.jpg This rubber insert fits the inside of the cupholdersplus aluminum cup holder perfectly https://cimg8.ibsrv.net/gimg/my350z....ad449ba81f.jpg The job is easier if you remove the center console from the vehicle. It makes the dremel part easier. Plus there are a few screws the hold the under ash-tray plastic part you can remove it in one piece by simply unscrewing. https://cimg3.ibsrv.net/gimg/my350z....125f79aed4.jpg This factory screw will be re-used to install the aluminum cup holder from cupholdersplus.com. The cup holder comes with a hole in the middle already. https://cimg5.ibsrv.net/gimg/my350z....c19f4bdebd.jpg Factory screw and cheap fender washer. Fit depth is perfect. Just need a dremel to clear away some of the plastic to make it fit. https://cimg9.ibsrv.net/gimg/my350z....d3934527bf.jpg Finished. |
