DIY for stock non-Brembo to stock Brembo brakes
on
DIY for stock non-Brembo to stock Brembo brakes.
If you’re planning to do this one here is what you will need:
Front/Rear Brembo Calipers and rotors
Brake lines – Brembo stock ones or aftermarket SS lines
Brake fluid
Brake pads (for Brembos)
4 Caliper bolts for the rear calipers - Nissan part # 080412351A. (fronts are the same so you can reuse what you already have)
(Also in this pic are some aluminum hub centric rings I got from SPL Parts)
OK for the obvious:
Jack the car up on all 4 corners and put it on some jack stands.
Take all 4 wheels off.
You now want to disconnect the brake lines from the inside of the wheel well as seen circled in these pics.
You will then remove the small metal shim that keeps the rubber line attached to the mount at this point as well. (be warned brake fluid will leak) You can use a small rubber cap (as I did) if you have one to cap off the brake line to prevent lots of leaking.
In the front you will also need to unbolt the brake line from the shock and the suspension of the car. In my case I used stoptech lines so I removed the whole mount (for the brake line) from the suspension.
Now you will need to remove the stock calipers. There are two bolts holding each caliper on. In the rear they are 19mm and in the front they are 22mm. These are the bolts you will be reusing in the front and replacing in the rear.
Once these are removed you can remove the caliper along with the rubber brake line which is still attached. Now remove the rotors. The rears may stick a little. Don’t be afraid to use a rubber hammer to bang them loose as I had to do.
For those that are interested –side by side comparison of rear rotors.
You can now slide the stock brembo rotors on in the front and bolt on the brembo caliper. At this time you can also install the brake pads.
The rear is a different story. There is a little lip on the dust shield which sticks up and will get in the way of the much larger rotor. This shield is not easy to remove and I didn’t bother to go that direction. Instead you can just trim the shield. I tried several methods and found the easiest way for me was to use tin snips and cut the lip off. I then used a dremel to smooth the sharp edges down.
After this is done you can install the rear rotor and bolt on the rear caliper with the new bolts. Also go ahead and install the brake pads for the rear.
Now it’s time for the lines.
The rears are a straight shot from the caliper to the inner wheel well connection. Install the same way you tool the old lines out.
The fronts are the same if you are using stock lines. If you ss lines as I am you can mount it to the suspension (without the bracket) and then to the inner wheel well connection. You can use the stock shims to remount the ss lines.
After your line is connected all you need to do is bleed your brakes. After this is done you may need to bed in the brakes. There are plenty of threads on bleeding and bedding so you can search if you’re not sure what to do.
https://my350z.com/forum/brakes-and-...tem-bleed.html
Final product:
If I need any corrections please feel free to reply.
Brake fluid
OK for the obvious:
Final product:
on
Very nice and very helpful. Now I just need to find a nice set of OEM Brembos. I've been looking at the ones for sale for the 2006, but no pics so I will have to keep looking. The ones you bought looked very clean and in great shape.
Edit: Jeez fixed all the bad typos
Nismo 370Z #697
Goodluck with your search bro I'll keep you on the update if I see a nice set floating around. Theres gotta be some people urging to upgrade to 6p/4p BBK.
Btw, this is an awesome write up! Nice and clear details. Only thing to watch out for is trimming the rear heat shield and making sure you bend the front back a little. For 2-3 days I couldn't figure out what was rubbing my rotors and it wasn't the back, it was actually the front head shield (which you don't need to trim).
on
Originally Posted by Bahraini350Z
A very nice and useful write up
One question, will the SS lines go to the caliper itself or to the extention lines coming out of the caliper?
on
Originally Posted by Scarab440
the stoptech lines go from the caliper (using banjo bolt) to the hardline in the inner fender. they replace the whole OEM rubber line assembly.
Originally Posted by Michla22
Yeah what he said - most SS lines are to the caliper itself (replacing the existing metal line for brembos).
coz I have bought the calipers from a totaled Z and they were missing the metal lines of them
Just ordered a set of Goodridge SS lines and hope they cover what is missing
on
So, if I were to get my friends G35 Brembo's there's no issue about fitment, etc? I am more concerned about my non-brembo calipers/rotors fitting on his car (he's trading it in to the dealer)...
on
on
The brembo's I'm using are from a G35 - not sure about your stockers on a G - should just be able to reverse the process for his car - rear heat shields will be a bit larger than need be - other than that i can't think of anything that would be a problem.
on
possibily a n00bish question but.....if i am ever able to get my hands on some stock brembos, can I do this one brake at a time with the OEM jack stand?
also, for my 2007 350z, which years Brembos will fit?
on
Yes you could do this one corner at a time and I can see not wanting to spring for a nice jack- HOWEVER - it would be worth while to get 4 jack stands to set the car on.
Just go out and get a cheap walmart jack or somethings if your worried about cash - it will save you a big hassle.
I beleive it's the same brembos for every year since 2003 - I did remember reading:
https://my350z.com/forum/showpost.ph...58&postcount=3
So they should fit fine and work fine but according to this member in his reply on another topic it looks as though the newer brembos have a little more torque.
on
Do not take a chance on this. I know a guy that died several years ago trying to work on his car with the stock jack.
Are there any fitment issues with the stock wheel offset and the Brembos?
on
on
Man, do not even attempt this with the stock jack It could possibly slip while you are under it and damage your car or worse injure or kill you. Buck up and buy a hydraulic floor jack and jack stands from Wal-Mart.
on
Mad Scientist
on
All of the stock wheels for all years will fit over the Brembo brakes. This includes 17" base wheels but does not include the 16" spare that comes with non-Brembo cars (as noted above).
Chris
Chris
