DIY - ARP Wheel Studs
Old 04-01-2011, 06:10 AM
vtchang
vtchang's Avatar
Default DIY - ARP Wheel Studs
Pixs to come. Please Pardon my grammar and spelling. I realize there are other ways to do this process. Perform this DIY at your own risk.
Tools:
Universal Ball Joint Separator (KD 3916) Sears # 00996404000
1/2 Ratcheting Drive
5/8" Socket
22 mm Socket
ARP Studs 100-7716 * 4 packs (They will say Subaru WRX/STi, but also fits 350z)
Front:
1) Jack up car and put jack stands on jack points identified in https://my350z.com/forum/8293361-post1.html
2) Remove Rims.
3) Remove Brake Caliper w/ 22mm Socket. There are two bolts on the backside of the caliper. Torque Specs on these things are 113 lb-ft so use the 1/2" drive and pipe.
4) Remove Brake Caliper from Rotor. The caliper will simply slide off the rotor. Be cautious of the brake line. Don't use a screw driver or anything to pry in between, you may score the surface of the rotor or scratch those sweet baby Brembos.
5) Tie up the Brake Caliper to upper A arm or anything else up high to keep it from hanging. Place rotor somewhere face hat down to keep the surface of the rotor's face safe from grease/oil.
6) Give the wheel bearing a quick spin. There should be a slight resistance. If the wheel bearing spins freely, you'll need to buy a new wheel bearing and right now would be a good idea to replace it.
https://my350z.com/forum/brakes-and-...nt-how-to.html (start at step 6)
7a) Time to use the ball joint remover! Place the ball joint remover's pivot pin on the TOP hole to create the largest opening. Place the ball joint remover over the studs and hand tight the compression bolt. Use the 5/8" socket and start cranking down. The stud will come out after a handful of cranks. Once the stud is loose, rotate the hub until about 11am. There is a slight notch in the dust shield to allow the stud to come out.
7b) Repeat 7a until all studs are out
8) Time to press in the arp studs. Get one arp stud and insert it into the hub through the notch in the dust shield. Use an open ended wheel lug nut and secure the stud into place.
9) Place the ball joint remover's pivot pin on the BOTTOM hole to create the smallest opening. Place the ball joint remover in the reverse orientation. You are now pressing the back of the stud through the hub.
10a) HINT! MAKE SURE YOU HAVE THE BALL JOINT REMOVER LINED UP PROPERLY. The more centered on the back of the wheel stud the easier your life will be. There is a sweet spot on the back of that stud that will help you press it in evenly. The point of the open ended wheel lug nut is to keep the stud centered.
10a-1) Don't worry if the stud goes in sideways, just back the ball joint remover up and try again. Don't need to press the arp stud out again. Just press the other side in. IF THE STUD GOES IN SIDWAYS, BACK OUT THE LUG NUT!
10b) Ensure the back side of the stud is completely flush with the hub.
10c) LEVERAGE is key. Notice where the ball joint remover is sitting on the hub and the direction of the 1/2" drive. (no pix, but once you start, you'll know what I mean)
11) Repeat until you got all 5 of them in.
12) Time to put the caliper and rotor back! Slide the rotor back onto the hub but do not slide it flush onto the hub. You will need to slide the caliper back onto the rotor. Slide the caliper back onto the rotor. This may require some muscle. Be cautious of your fingers as they are holding the caliper. You do not want any grease to come in contact with the brake pads.
13) PUT ANTI-SEIZE on the caliper bolts! Align the caliper and hub holes to HAND tight the brake bolts holding the caliper to the rotor. The caliper's metal is soft, the last thing you want to do is mess up the threading on it. Once you finish hand tightening the bolts, torque them down to 113 ft-lbs.
Done
Attached Thumbnails DIY - ARP Wheel Studs-cimg0723.jpg   DIY - ARP Wheel Studs-cimg0721.jpg   DIY - ARP Wheel Studs-cimg0719.jpg   DIY - ARP Wheel Studs-cimg0716.jpg   DIY - ARP Wheel Studs-cimg0715.jpg
Old 04-01-2011, 06:29 AM
vtchang
vtchang's Avatar
More Attachment Space
Attached Thumbnails DIY - ARP Wheel Studs-cimg0713.jpg   DIY - ARP Wheel Studs-cimg0709.jpg   DIY - ARP Wheel Studs-cimg0707.jpg   DIY - ARP Wheel Studs-cimg0706.jpg   DIY - ARP Wheel Studs-cimg0705.jpg
Old 04-01-2011, 06:32 AM
vtchang
vtchang's Avatar
Even more attachment space!
Attached Thumbnails DIY - ARP Wheel Studs-cimg0704.jpg   DIY - ARP Wheel Studs-cimg0698.jpg   DIY - ARP Wheel Studs-cimg0695.jpg   DIY - ARP Wheel Studs-cimg0688.jpg
Old 04-01-2011, 06:46 AM
RandomHer0
RandomHer0's Avatar
Damn that tool makes this seems like cake. Well done.
Old 04-01-2011, 06:50 AM
huyrua
huyrua's Avatar
ingenious, good work
Old 04-01-2011, 09:22 AM
ZS14RR
ZS14RR's Avatar
Nice. Very useful
Old 04-01-2011, 09:41 AM
AcidJake75
Living in 350Z
AcidJake75's Avatar
ZING! I use a different type ball joint tool - but I will try this one next time..
good work - pressing them out is better than the good ol BFH action..
Old 04-01-2011, 09:51 AM
dikspiel
Chestons Toilet
dikspiel's Avatar
Is there any reason to do this besides because you want to use spacers and need longer studs?
Old 04-01-2011, 09:57 AM
vtchang
vtchang's Avatar
Some aftermarket rims have larger backspacing. I couldn't get full thread lock on OZ Ultraleggeras. This can be dangerous if you plan on doing anything aggressive. Plus, tech won't pass you for any sort of organized event (AutoX, HPDE, etc).
http://www.youtube.com/watch?v=vnwf2JWcgg8
Old 04-02-2011, 09:08 AM
nismofreak1208
nismofreak1208's Avatar
^^^^^so true
Old 02-07-2013, 08:39 AM
pfregeolle
pfregeolle's Avatar
I'll be installing my ARP studs next weekend, so I'm so thankful for this thread, and dead-on details. BTW, for anyone looking for the ARP studs at a pretty decent price, I got mine through VR-Speed in Michigan for about $124 shipped.
http://www.vr-speed.com/arp-subaru-w...-100-7716.html
Old 02-08-2013, 07:18 PM
freddys 350z
freddys 350z's Avatar
the only thing i dont like about that tool is that when the stud comes out, it FLYS out(pops out) and the tool falls. if you ever used it you know what i mean.
Old 07-03-2013, 01:54 PM
reserved
reserved's Avatar
Just bought that tool. It obviously works for the stock studs. It doesn't work for removing ARP studs though; they are too long. Any suggestions? (apart from using a hammer, which I don't want to do!)
Old 07-15-2013, 01:40 PM
ian99rt
ian99rt's Avatar
pull the hub and a shop press. After you pull the original studs the new studs can come out a good bit easier. ive hammered mine out a few times for various reasons.
btw alot of tire shops will run into a messed up stud and replace it without telling the owner. guess how they get the old stud out.
Old 07-15-2013, 03:49 PM
dcains
dcains's Avatar
Does this work on the rear studs, too? Is there enough clearance?
Old 07-15-2013, 03:54 PM
ian99rt
ian99rt's Avatar
You have to pull the parking brake cable and mechanism out and feed the studs thru the cable's feed thru hole.
Old 07-15-2013, 03:55 PM
dcains
dcains's Avatar
Thanks.
Old 02-06-2014, 03:33 PM
NA&CH
NA&CH's Avatar
Easiest way to install APR studs on the rear is?
Fronts are done.
Chris
Old 02-07-2014, 07:40 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
Fronts are done.
Chris
Post 16 unless you want to remove the bearing and hub assembly and do it on a press.
I have only done a couple on a press, only because I was replacing bearings at that time.
Old 10-13-2014, 05:24 PM
jdepe
jdepe's Avatar
how long are these studs? I am trying to figure out if I need to get new lug nuts. My current ones are 40mm.
Quick Reply: DIY - ARP Wheel Studs
