MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Brakes & Suspension (https://my350z.com/forum/brakes-and-suspension-399/)
-   -   because I'm cheap... tires and sway adjustment question (https://my350z.com/forum/brakes-and-suspension/102130-because-im-cheap-tires-and-sway-adjustment-question.html)
sentry65 Dec 10, 2004 01:24 PM
just thinking of this as an alternative to getting wider wheels and tires here as a short term solution
What if I put on BFG KD 265's on the rear of my track model, and to compensate for the understeer I'd get, I set my rear 350EVO sway bar to the hard setting. Would this keep the steering balance ok? My front and rear sway bars are set to medium right now.
my stock front tires are feathering. I had the alignment TSB fix at 1600 miles with my car being an 03 - so Nissan should give me a new set of front tires. My fronts still have quite a bit of tread left so this would work out assuming I go thru rears quicker than fronts.
sentry65 Dec 16, 2004 12:14 PM
just checking no one has any comments on how stupid this setup may or may not be?
what about 245 stock tires up front and 265 BFG KD's in back? how should I set my sway bars?
