Aluminum Camber Adjustable Upper Control Arms?
Any adjustable camber upper control arms made from aluminum? How about the 350Evo arm?
I think the Cusco, Stillen, and kinetix are chromoly steel. It seems stupid to replace the stock aluminum with steel.
Respect
JET
Respect
JET
on
Respect
JET
Respect
JET
on
I can't say enough good things about the 350Evo arms. In my opinion the quality is better than the factor. I have run them plenty on the street and track and not had any problem with them bending or coming loose. The thing I liked best about the arms is the steering is alot smoother and responsive even on the steet alignment. This mod is well worth the money especially if you track your car.
I agree.... 350Evo arm is a great product. they are exlusive in that they they are aluminum, with spherical bearings. I'm getting a set. If you buy the full arm kit is there a spherical bearing kit available for people with the the arms package already to replace the other bearings?
Respect
JET
Respect
JET
on
i had the unitech arms, and switched to the 350evo's. look at what i went through to bring them closer to the specification of the 350 evo arms:
http://members.***.net/chadisrad/
(it is in the writeups section)
i now have the 350 evo arms and i love the adjustment, the quietness, and the smoothness. mostly, i like that they gave me another .5 degrees of positive camber adjustment.
Chad
Chad
Great work Chad! I can't even spell computer, and here you go posting PDF files!
FYI, Unitech is redesigning their A Arms, to allow more NEGATIVE camber!
Kind of off topic......I just bought/got my SPC rear camber arms with toe links. Looking at the included instructions & your install, it appears to me that the slot elongated will move the CAMBER, not the toe. I'll be lowering only about 20MM with the Unitech/Truechoice Koni's soon, so I wish to do it correct the 1st time, but I'm confused.
on
the bolts in my writeup definitely adjust toe. the camber rods will adjust camber, and the bolts that on the spring buckets will adjust toe. keep in mind that the adjustment points where the suspension attaches to the spindle are off center, so you can never truly adjust camber or toe independent of the other.
Former Sponsor
on
08-06-2021 06:19 AM
04-04-2016 07:52 AM
350Z Project X
Suspension
10-10-2015 09:23 AM
CFAUVEL
10-01-2015 03:20 PM
