What's a "dry brake" system?
Somewhat off-topic, but I was watching Calvin Fish explain how they change the whole monobloc caliper in the Daytona 24 hour race. He mentioned that it's a "dry brake, so there's no fluid, no bleeding has to be done..." How can this work? There were bleeder valves on the caliper, so I assume it's got fluid in it. If he misspoke about the "dry brake," I would still think you'd need to bleed the thing if you disconnected it, and he said they could do a caliper/rotor change in under a minute.
uwaeve |
FOund that using Google...
http://www.findarticles.com/p/articl...05/ai_n8839474 |
Interesting...
Good stuff...
It's about time for something like this! I especially like the fact that it uses less parts and weighs considerably less. Application list please!!
I wonder what the pedal feed back feels like...
Thanks, Kolia.
Very interesting. Google must not have liked my search string or something. Or I'm an idiot. One of the three. I bet you can make the pedal feel however you want, since it's no longer directly connected to the hydraulic system. More like brake-by-wire. In fact, you can probably make it the perfect pedal: pressure sensitive with no displacement. uwaeve |
Don't car makers currently install diagonally seperated brake systems so that in case something goes wrong, you can still brake more or less straight ? What would heppen if one of the motors breaks or a "corner" start leaking ? Wouldn't that get you in trouble the first time you brake, more than with a conventional system ?
Danny |
Danny Safety level will be at least on par to current systems. |
| All times are GMT -8. The time now is 08:12 AM. |
