Need Help.....Camber issuse!!
i've had tein basics on my car now for about 2 months. i havent gotten around to doing my alignment. the problem is that i want to purchase the front and rear camber adjusters and install them before i align the car. i really dont want to align it twice (before and after). the thing is i dont know what to buy, either camber adjuster or Toe adjuster or both. i read somewhere that the toe is only needed when upgrating to a bigger wheel/rim size. all i want to do is be able to fix/adjust the camber on my car.
Plz Help me out...i want my tires to last.
Your dropped around 3/4" in rear. You may be able to band-aid the problem with the stock suspension...?
But if you want your tires to last and have a little more susp. range, read this thread...
https://my350z.com/forum/brakes-and-suspension-diy/185737-spc-toe-bolt-install-write-up-with-pics-courtesy-of-protocav.html
GL,
Zquicksilver
GL,
Zquicksilver
on
Get the SPC rear camber w/ the toe bolt kit. It cost a lot less then other camber & Traction/Toe Arms and adjusts the toe where is actually needs to be adjusted. For the front, any kit will do, but I suggest the new SPC kit or the Cusco kit.
on
