350Evo Sway kit fitament question
so i was reading about swaybars & I have narrowed it down to either the cusco sways or the 350evo Sways. Both are about as stiff as the other however the 350evo sways are adjustable front & rear whereas the Cuscos are front adjustable only (and a little more expensive). However, the 350evo rear sway doesnt have the bump to clear the exhaust. So my question is does it fit? have any of you installed the 350evo rear sway?
The cusco fits perfectly, I dont know about evo350. I thought they stopped making things? They're actually almost the same in terms of stiffness. The additional adjustability doesn't really matter. You'll likely put it to the same stiffness as the cusco- unless you race often at the track.
