Wheel Spacers Track Wheels
Old Jun 23, 2007 | 06:52 PM
Dmorrisjr350z's Avatar
Dmorrisjr350z
Default Wheel Spacers Track Wheels
Hey guys, so as i have been seaching around the forums i have gotten a pretty good idea of what i need for wheel spacers with my Track Edition Wheels. A lot of people say go measure the distance between your fender and wheel that is what you need.. Only problem is i am lowering my car (tein basics) and putting on the wheel spacers at the same time. I have read some do 15mm in the front and 20mm in the back and some say 10mm front and 15mm in the back. anything i should know about before making this purchase? Tein Coilover/wheel spacer problems etc?
Thanks in advance guys!
Dave
Old Jun 23, 2007 | 11:53 PM
XuperXero's Avatar
XuperXero
I'm getting 25mm rear and 20mm front for my OEM rims which is 18x8 all around, but +33 offset rear and +30 offset front. So for the track rims since the rear is 8.5" wide instead of 8. I recommend 20mm all around as the front is the same spec/offset as my OEM rims. You shouldn't have clearance issues at all with this spacer specs.
Old Jun 24, 2007 | 04:35 PM
drumminguy81's Avatar
drumminguy81
i have the track rims my car is lowered on tenabe nf210 1.2'' all the way around and i have 25mm spacers on the rear.. it is extremely close! but as far as i can tell no rubbing. though i think if i hit a really hard bump it may.. i am also running 255-35 tires.. hope that helps...
Obadabot
Jun 18, 2023 11:31 PM
