Most comfortable coilovers for daily driving?
Old 09-02-2007, 03:38 PM
Mr_Drifter
Mr_Drifter's Avatar
Default Most comfortable coilovers for daily driving?
So I'm getting rid of my current setup and switching over to coilovers. What I am looking for is a coilover that is dampening adjustable and rides really smooth on the street. The car is not tracked at all, so I don't want high spring rates. I want to stay right around $1,000. I am currently looking at the BC Racing coilovers, but if you guys can suggest something, that would be great.
Old 09-02-2007, 07:13 PM
Z1 Performance
Former Sponsor
Z1 Performance's Avatar
the BC's are ok for what they are. Don't expect stellar results, but they ride acceptably enough and have a decent dampening span. Fairly typical for lower end coilovers at that price point.
Old 09-03-2007, 01:06 AM
Mr_Drifter
Mr_Drifter's Avatar
what do you suggest?
Old 09-03-2007, 01:07 AM
Mr_Drifter
Mr_Drifter's Avatar
I'm also looking at the Bilstein PSS9's which I can get for at cost.
Old 09-03-2007, 05:53 AM
Z1 Performance
Former Sponsor
what wheels and tires are you running? Also, have you budgeted (or do you have) for the front and rear camber solution that you're likely to need with lowering the car on coilovers?
Old 09-03-2007, 06:47 AM
CESAROTORRES
CESAROTORRES's Avatar
Default Hks Rs
It would be the HKS RS but, you will need to spend a little more.
Cesar
Old 09-03-2007, 10:02 AM
Mr_Drifter
Mr_Drifter's Avatar
i'm running 19x8 and 20x10 on 245/35 and 285/30 on 1 piece wheels. and yes, I have the camber issue already sorted out.
Old 09-03-2007, 10:18 AM
97supratt
97supratt's Avatar
I think that's a oxymoron, comfortable coilover. lol
Old 09-03-2007, 11:38 AM
Mr_Drifter
Mr_Drifter's Avatar
what does it mean when a coilover is progressive in the rear?
Old 09-03-2007, 04:00 PM
Z1 Performance
Former Sponsor
there are plenty of comfortable coilovers out there - good performance and comfort, at least in my world, should not be mutually exclusive. We're not building LMP cars here, we are building, presumably most of us, real world street cars. If the coilovers you choose don't offer better than OEM dampening, you made the wrong choice.
A progressive rear means the spring is progressively wound. This means the coils at the top of the spring, have a softer rate, and as the spring compresses, the rate gets stiffer. Several manufacturers (the Euro ones), employ this technique to give a ride that provides a great balance between comfort and sportiness. For all out track use, a straight linear setup is ideal, but for everyone else out there, the progressives give a nice balance, and is an easier way for the manufacturer to make their setup, vs employing specialized and exotic valving techniques
Old 09-03-2007, 04:12 PM
97supratt
97supratt's Avatar
He wants to spend around $1,000. There aren't any coilovers I know of that are comfortable for around $1,000.
Old 09-03-2007, 04:14 PM
Z1 Performance
Former Sponsor
I understand that...and that's why I posted what I posted
Old 09-03-2007, 04:15 PM
97supratt
97supratt's Avatar
gotcha.
I've heard good things about the tein CS coilovers.
Old 09-04-2007, 03:40 AM
tekk
tekk's Avatar
another vote for hks rs. its more than $1k but i found it to be able to be even as comfortable as (if not more so) than stock if thats what you want... and i have a g no less...
Old 09-04-2007, 10:57 AM
Triple8Sol
Triple8Sol's Avatar
Tein Basics might be your answer?
Old 09-04-2007, 01:42 PM
y0shi
y0shi's Avatar
HKS RS ftw
Old 09-04-2007, 01:46 PM
izmir41500
izmir41500's Avatar
no way. comfort goes out the door with the high spring rates. the price fits, but there is not dampening adjustability. you also have to consider install costs. $1 isn't going to get you anything you want unless it's used.
Old 09-04-2007, 09:59 PM
adrianko43
adrianko43's Avatar
Get a shock with adjustable dampening (such as the koni yellows) and match it with a spring with your desired spring rate. If you want ride height adjustability,there are some shocks with threaded collars. (i know kyb makes them for subarus)
Old 09-05-2007, 08:52 AM
BrianLG35C
BrianLG35C's Avatar
Which one has the more comfortable/OEM feel, PSS9s or Tein CS?
Old 09-05-2007, 09:13 AM
eemon10
eemon10's Avatar
how is handling on HKS coils?...im guessing it prob wont we as good as something like tein flex but how are they performance wise?
Quick Reply: Most comfortable coilovers for daily driving?
