MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Brakes & Suspension (https://my350z.com/forum/brakes-and-suspension-399/)
-   -   Brake Dillema!!! Brembo's or stoptech front (https://my350z.com/forum/brakes-and-suspension/31576-brake-dillema-brembos-or-stoptech-front.html)
daytona350z Jun 2, 2003 03:20 PM
im in this little fight with myself.
i have the opportunity to buy a whole set front and rear of brembo brakes that were on my friends g35 coupe for a price of around 1800$ which includes everything i need to upgrade my crappy touring brakes. but i dunno weather to spend the money on a stoptech 13in. set.
what should i do? a complete set of brembos or a front kit of stoptech's?
MannishBoy Jun 2, 2003 03:31 PM
For that money, I'd go Brembo first, Stoptechs second. You are spending virtually the same amount of money and getting all four corners. Most guys that have the track model and actually track it seem to have little desire to upgrade. I think a lot of people would jump all over that price on the Brembos.
What did he put on?
I'm figuring I'll go junk yarding in a year or so and be able to find Brembos pretty reasonably with track Zs and G35Cs both having the Brembos, if I decide at the time I want a set of brakes :)
cbsuper Jun 2, 2003 03:39 PM
Get the stoptechs. The Brembo system is damned expensive.
MannishBoy Jun 2, 2003 04:01 PM
He's buying a take off set for $1800 for all four corners. Not that expensive. The front stoptechs are more.
cbsuper Jun 2, 2003 04:21 PM
Oh, I thought he was talking about getting a true Brembo upgrade. :P In that case then, get the Brembo setup.
nwind21 Jun 2, 2003 04:33 PM
if you're considering stoptechs you can always look at AP kits too.
React3 Jun 2, 2003 05:42 PM
www.gruppe-s.com you can find them cheaper (stoptech) just email them...
But APracing makes a rear kit that fits with the stock rotor (2-pot caliper) Think about it.... Good luck
westpak Jun 2, 2003 05:55 PM
I would say it depends on what you are going to do, if you are going to the track and drive it hard there then you might want to get the Stoptechs if not definelty the Brembos.
I had an instructor with a Track model at Sebring and he had changed the fronts to Stoptechs and was happier.
n8vz Jun 2, 2003 08:38 PM
4 piston vs. 6 pistons fronts
My Track has 4 piston fronts. Still breaking the car in so haven't had a chance to utilize the brake's full potential. Now back to the main point. Many of the newer brake system upgrades feature 6 piston fronts. Is StopTech such a system?
D'oh Jun 2, 2003 11:19 PM
Re: 4 piston vs. 6 pistons fronts
Stoptech has 4 piston fronts.
Daytona, how worn are the pads you would be getting with the Brembo kit? That might be something to check out.
I know that with the stock rears wear out quite fast, but are also cheap to replace. Don't know how well the track rears hold up, but since they are slightly bigger, they probably last a bit longer.
If you get stoptechs you will still need to replace rear pads pretty frequently if you are tracking often. With Brembo's you may not need to do that.
I will probably get the Stoptech 13" Front Kit for my Performance Z, but the Track Brembo's sure are nice as well. I think you'd be fine with either kit, and therefore can't really go wrong.
-D'oh!
MannishBoy Jun 3, 2003 04:44 AM
A downside I've heard about the Brembos are the rotor replacement costs, though. Aren't a set more than $500, compared to low $100s for the standards? Of course, I think you can turn the Brembo rotors more than the 1x or so you can do with the stock ones. Don't know about the rotors on the Stoptechs.
daytona350z Jun 3, 2003 02:29 PM
im thinkin of goin with the full brembos
thanks
daytona350z Jun 3, 2003 08:08 PM
Originally posted by VQracer
Brembos, I'm biased.
Victor :D
already purchsed them...they are goin on in a week or two:D :icon04: :icon4:
jckolnturn Jul 1, 2003 06:37 AM
How did it come out and are they a straight bolt-on replacement for the stock non- brembo's
was wesman Jul 1, 2003 09:48 AM
If you're considering either of those consider Willwood...I'll have the 6-piston front kit on in a week or so. It's my understanding they will be priced similar to the others. I'll provide info when I have it for sure.
--wes
GaryK Jul 1, 2003 11:35 AM
I was going to recommend the Stoptech or AP front kit over the full Track setup. The bulk of the braking is done with the front, and on most cars like the 350z there really isn't a need to upgrade the rears for performance reasons. If the weight distribution was more like a 911 (like 65% on the rear), then you would benefit from a rear brake upgrade.
Also, the Wilwood kits are generally ok if you are upgrading just for looks, but the calipers they usually include don't even begin to compare to AP, Stoptech, or Brembo. They do make some good calipers, they just don't sell street kits with the good calipers. That's why their kits are usually pretty cheap relative to others.
daytona350z Jul 1, 2003 02:29 PM
i'll take some pics and post them when i get back from my trip on the 14th
MannishBoy Jul 1, 2003 03:10 PM
The problem is a lot of people using stock brakes are having problems with very fast wear on the rear pads because those brakes are so small. There is a theory this is due to the electronic brake force distribution trying to compensate too much.
I'd agree with you if it was going to cost $4-5K to do all four, but he got the 4 Brembos for less than the cost of the front kits.
Nocturnal Jul 1, 2003 04:40 PM
I have searched hi and low, but I couldn't find the AP racing 2 POT rear brake...who have it? I have heard of this for ages, but I couldn't find this thing. I have heard it uses the stock 322mmx22mm track rotor if I am correct, right? That brake will go so well with the 363mm 6piston brake kit... :rolleyes:
GaryK Jul 1, 2003 06:01 PM
From what I understand, the only ones really having problems with rear brake wear are running with VDC on. On the track or autox, you should not be running with it on. Even if you have problems without VDC, it could be caused by inadequate front brakes. Since the fronts do most of the work, the puny stock (non-Brembo) front brakes will start to fade quickly, shifting the bias to the rear. Then, the rear compensating for the diminishing performance of the front brakes. This is just my opinion based on a lot of experience with different cars.... I haven't done anything more than autox my z yet, and stock touring brakes are adequate for that BTW.
I'd still take the Stoptech front @ 2k versus the Track brakes....and I think they can be had for less anyway. Of course, this is coming from a racer, not a boulevard cruiser. The Track setup does look good, I have to admit....but "zing" comes before "bling" in my list of priorities. :D
