What do failing shocks sound like?
Old 08-30-2008, 06:39 PM
  #41
WTX350Z
WTX350Z's Avatar
bearing slipped off the bearing? this makes no sense....bushing rather than bearing?
oh and your way of checking for bearing wear is faulty...FWIW
Old 08-30-2008, 07:16 PM
  #42
Spork
Spork's Avatar
Yeah, I believe it's the bushing. My bad.
Brass inner shaft that control arm can rotate on = bushing, correct?
Old 08-30-2008, 09:45 PM
  #43
WTX350Z
WTX350Z's Avatar
sounds like it. Strange to hear its torn up. how many miles are on the car? Have the LCA's ever been removed to your knowledge?
Old 08-30-2008, 09:48 PM
  #44
Spork
Spork's Avatar
Last time I checked it was nearing 69050. It's a 2003.
To my knowledge, they've never been removed.
Old 08-31-2008, 04:45 PM
  #45
terrasmak's Avatar
Received 2,283 Likes on 1,645 Posts
Is there any way you can post a pic of what the dealer found , it could be a learning experiance for us. My car has about the same amount of miles and gets flogged on the track, if it happened to you , it could happen to me and others.
Old 08-31-2008, 06:41 PM
  #46
Spork
Spork's Avatar
Sure. Either a little later tonight or tomorrow I'll jack up the car and take a clear picture.
Old 08-31-2008, 08:04 PM
  #47
Spork
Spork's Avatar
Here's the pics. This is the worst side, the driver's side. The passenger side is halfway there.
Old 08-31-2008, 09:01 PM
  #48
gregom
gregom's Avatar
Holy crap that is completely effed... it should be in the center like this:
That price sounds about right for the lower control arm... how the hell did this happen though? Did you hit something or run over a curb? Don't know how they would get dislodged from the crossmember... thats crazy.
Old 08-31-2008, 09:54 PM
  #49
WTX350Z
WTX350Z's Avatar
yup, the rubber just gave out looks like. I'd goto an aftermarket piece personally....will give you other options...and you can goto a more "rugged" bushing.
Is your car red? or did you paint your calipers red?
If car, then its been wrecked, if calipers then try masking next time!
Old 09-01-2008, 12:11 AM
  #50
Spork
Spork's Avatar
I painted my caliper and didn't disconnect the brake lines.
Found the Nissan LCA's for $163 each. Replacing the endlinks as well, since they're $14 each.
There aren't any aftermarket lower control arms.
Old 09-01-2008, 12:44 AM
  #51
terrasmak's Avatar
Nothing aftermarket as far as LCA's , but you can just get the Nismo bushing installed for now.
Old 09-01-2008, 05:10 AM
  #52
Ed 718
BRAVEHEART
Ed 718's Avatar
Ben there is a salvage yeard near me that get's a ton of Z's if you want I can look around and get you a price for a control arm...............let me know.
The same salvage yard got me a low mile tranny and engine and it works fine. The tranny was a cd009 or the lastest one and the engine has almost 15k on it.
Old 09-01-2008, 02:10 PM
  #53
Spork
Spork's Avatar
Oooo thanks Ed. I can get the new LCA's for $163 each, which is okay over the quote of $222 the dealer gave me.
How much do you think that 009 tranny would cost? I have the standard 03 one, and the gear grinds irk me every now and then.
Old 11-11-2008, 08:47 AM
  #54
koolzero
koolzero's Avatar
Default I have a creaking noise also...
My car only has about 32,000 miles but it's an 03 and it is making a creaking noise, it sounds like what is being described here. I had the Nismo susp then lowered the springs with the tanabe's. Is it possible that the endlinks would go bad with this realatively low amount of miles?
Is it not possible to just replace the bushings on the lower control arm, are are they attached?
Old 11-29-2008, 11:34 AM
  #55
grimace65
grimace65's Avatar
tropic thunder licks *****
Old 11-30-2008, 10:29 PM
  #56
wutafobb
wutafobb's Avatar
I have the same problem! I had to replace my right lower control arm, it was so loose my wheel almost fell off. Now my left is making the same noise. I hear a clunking noise every time i turn my wheel and try to enter a incline or bumps.
And worst thing is my ride sucks, i feel every bumps, do you guys have the same problem with ride being really harsh yet bouncy? Thanks
Old 12-01-2008, 07:24 AM
  #57
koolzero
koolzero's Avatar
I replaced the front swaybar endlinds and am still hearing the creaking noise. My left lower control arm looks okay to me. When I back down the slope of driveway I turn my steering wheel hard to the right and this is when I get a creaking noise. It sounds like it's coming from the steering wheel knukle area, I wonder if if it safe to try a little extra grease on the gears of the steering wheel knuckle to see if it does any good.
Old 12-01-2008, 08:18 AM
  #58
wutafobb
wutafobb's Avatar
hows the ride tho?
Old 12-01-2008, 10:51 AM
  #59
koolzero
koolzero's Avatar
I think it rides fine.
Obadabot
06-18-2023 11:31 PM
Justin100
11-29-2015 03:58 PM
derekinthez
South East
09-28-2015 06:35 PM
samansharif
09-25-2015 12:31 PM
Quick Reply: What do failing shocks sound like?
