MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Brakes & Suspension (https://my350z.com/forum/brakes-and-suspension-399/)
-   -   Suspension Guru's Please Help (https://my350z.com/forum/brakes-and-suspension/429717-suspension-gurus-please-help.html)
jdmteg2nv Apr 17, 2009 11:56 AM
I tried searching but I can't find a definite answer....Over the past few months I've noticed a clunking noise comming from my front suspension..it started on both sides then got progressively louder on the passenger side...and now if the vehicle is stopped and i turn the steering wheel to the left and begin to accelerate I hear and feel a rubbing noise from the front passenger side..almost like a wheel is rubbing on a fender liner but it's not
I'm on stock suspension and have 19" rims with 19x9 on 235/35/19 and 19x10 on 275/35/19
Thanks for your help in advance
WhiskeyHotel Apr 17, 2009 01:44 PM
Do you have aftermarket sways? It could be the endlinks. How many miles? year model? Does it go away after you accelerate?
jdmteg2nv Apr 17, 2009 02:25 PM
factory sways....its 03 touring, 6-speed, 30k on it,...I notice the sound is more frequent when the car is cold and doesn't occur as much after the car heats up
jdmteg2nv Apr 17, 2009 06:09 PM
ok just took off the front sway bar and endlinks and went for a quick drive and still hearing the same noise...
anybody have some suggestions to help troubleshoot to find out what the noise is
WhiskeyHotel Apr 17, 2009 07:42 PM
Can you shake the front wheels while it's off the ground - wheel bearings? I also think there was a TSB about improper torque on the upper A arm bolts. You might try re-torquing them.
Do you feel it in the steering wheel or just hear it?
jdmteg2nv Apr 17, 2009 08:02 PM
don't feel anything on the steering wheel just...hear the noise...it is definately louder on the passenger side but it you can hear it on the driver side....
what do you mean shake the wheels??? like in and out or left and right??? Also is it common for both wheel bearings to go out around the same time
do you know what the torque is supposed to be on the upper A arm bolts??
thanks for the help
jdmteg2nv Apr 19, 2009 02:49 PM
found the TSB on the upper A arm bolts..checked the torque on them and everything seems fine....would blown shocks cause this clunking noise?? any other ideas??
Eddie K. Apr 20, 2009 07:08 AM
It sounds like it's your frount struts are bad . I had a Nissan Maxima do the same thing. New struts and clunking noise gone.:D
WhiskeyHotel Apr 20, 2009 08:23 AM
If your wheel bearing are worn, you can move the wheels slightly top to bottom. Give it a bit of a shake. With only 30K, it's unlikely but worth a try (also unusual for both to go belly up at the same time.)
It could be the front struts as above. I don't knwo how you would tell short of replacing them, though.
Zoom750 Apr 20, 2009 11:31 AM
I am also experiencing a problem with my front suspension (G35 Coupe). Things you may want to inspect, from what I've gathered so far:
-sway bar brackets (since you've already eliminated the endlinks)
-wheel bearings
-compression rod bushings
-lower control arm bushings
-blown shocks?
FWIW, will be bringing the car to the dealer this Wednesday. Will post up results. G/L
MB07 Apr 20, 2009 12:52 PM
i think I have the exact same problem as you.. my best description to this noise is it sounds like a seal is stuck in my suspension. I also mainly hear it when its cold(er) and not as much when the car is warmed up. Im in an 04 roadster 6spd as well no mods.
jdmteg2nv Apr 20, 2009 03:59 PM
yea I have no clue what it is...I looked at the seals on the brackets and control arms and they seem fine...
I tried to jack the suspension up and down with the wheel on it to simulate a bump..but couldn't reproduce the same noise...
I put the factory wheels back on to see if the noise would change and still the same...
Hopefully its blown struts..gives me a reason for coilovers :)
MB07 Apr 20, 2009 04:30 PM
well when i first got this car (used) i had THE MOST ANNOYING rear squeak and it turned out to be the shock assembly top bolt was loose. My mechanic took it down and took it apart to see if there was anything visibly wrong, there wasnt and when he was assembling the shock back together that top bolt went so much further down.. sure enough it shut up. So im gonna head to the mechanic tomorrow and see if we can figure somethin out ill let you know if i do. I'll tell you this much, I did need a balljoint regardless and I changed it hoping it would kill that problem too and it didnt do a thing for the noise.
MB07 Apr 23, 2009 07:35 AM
So I went to the mechanic and of course it's quiet. Here's the funny part it was raining I never really paid attention before but does it really silence when it's wet or am I just crazy? Either way we traded cars for the night cause I know for sure in the mornings it does it and he heard it!! That's as much success as I have to give at this point. He looked long and hard at everything and it's driving him nuts. He says the G and 350 are known for that lower control arm (the one further back) it's like a big L but that's a $350CAD test :S my bushings there aren't in the most fantastic shape but they're not bad. I found a Z shop here in Toronto that strictly work on Z's new and old so I'm gonna hopefully pop by tomorrow and see. We will all beat this car!! It's not gonna win versus all of us lol
jdmteg2nv Apr 23, 2009 02:37 PM
Well I found out the problem it turns out that my upper strut bar was loose and was making the clunking noise...so the problem is solved..hope this can help somebody else out...
So i'm probably going to take off the strut bar...because it is dangerously close to the upper intake manifold
MB07 Apr 24, 2009 07:26 AM
stupid question... can i just unblot the strut bar and obviously bolt the bots back in nice and tight and drive without it at least until I even go grab an aftermarket bar just to make sure it really is my problem as well? Reason Im askin is cause my car hasent been driven yet today and it will for sure make the noise when I go to leave and if i do this unbolting business and it dosent do it when i start driving today then I'm solved as well (fingers crossed)
DivinDriver Apr 24, 2009 01:43 PM
Did you try adjusting the strut bar, per the service manual? Might just be loose/out of whack. Properlty tightened, it shouldn't make any noise or have a clearance problem unless it's damaged.
MB07 Apr 24, 2009 02:40 PM
took the bar out completely and problem not solved for me :( still sounds like I have a seal (the animal) stuck in my front end :(
DivinDriver Apr 24, 2009 08:50 PM
This might sound silly, but have you checked the center caps on your wheels?
Had them get loose on another car once; about drove me insane until I found the problem.
terrasmak Apr 25, 2009 03:03 AM
https://my350z.com/forum/brakes-and-...g-failure.html look for this prob.
