Suspension newb with a couple of questions
A couple of days ago I installed a set of BC coilovers on my 06 350z. With the coilovers I also installed adjustable rear camber arms. The car feels a bit weird because it does need an alighnment. Fenders have been rolled already.
Wheel tire/specs: Front 19" x 9.5 with 25 offset Rear 19" x 10.5 with 22 offset Front 255-35-19 Rear 295-30-19 Besides the camber arms, what else do I need to install to get the alighnment done properly? I have read that toe arms are a bad idea, and that one should opt for the toe bolts instead. Any advice is apreciated. |
Originally Posted by BoostedProbe
(Post 7545769)
Wheel tire/specs: Front 19" x 9.5 with 25 offset Rear 19" x 10.5 with 22 offset Front 255-35-19 Rear 295-30-19 Besides the camber arms, what else do I need to install to get the alighnment done properly? I have read that toe arms are a bad idea, and that one should opt for the toe bolts instead. Any advice is apreciated. I have SPC rear camber arms and bolts and was able to get the rear back in to spec. My front camber is off. |
