Piecing together an Akebono Kit
So I have looked around at a few kits which were put together by some companies. None the less, I cannot say that they are offering exactly what I am looking for. I don't need SS lines and I don't like the single piece rotors and I also like to have a choice of pads. I looked around at putting together my own kit and figured I would post to see what I am missing as well as give others that are looking to do the same, some ideas. Here is what I have found. Please let me know if I am missing anything.
Calipers: $511.56 (http://www.courtesyparts.com/kb_sear...8724_8808_8809) Adapters: $225 (http://www.z1motorsports.com/350_g35...oducts_id=5332) washers: $9.96 (http://www.courtesyparts.com/41044a-...-p-637313.html) Bolts: $6.62 (http://www.courtesyparts.com/41000a-...-z34-2009-2011) Hardware kit: $101.80 (http://www.courtesyparts.com/41080k-...724_8808_8809&) 1 piece Rotors: $198 (various kinds) 2 piece rotors:$495.54 (various) Pads: $95 (stoptech)
Originally Posted by Guilty1s
(Post 9595553)
That is what i did, but i ended up selling it before putting it on cause of the 29lb rotors and bad wheel selection.
The only thing your missing is the pins and the clips. http://www.courtesyparts.com/41217-p...724_8808_8809& Personally, i said to hell with courtesy and started asking some of the sites vendors for some of the small stuff I got Hawk HP+ pads For the hardware kit and pins i think it was Z1 motorsports or CZP. Alot cheeper then courtesy. For the clips i went to ace. 7.07 X 8 vs .13 a piece... yeah... no brainer. All the caliper bolts you need, should already be there or with the brackets if you get them from Z1 PM me if you need any other info |
Have you gone here yet?? https://my350z.com/forum/brakes/4142...at-1200-a.html
I think you got everything. If 1-piece rotors do not suit your needs why are you pricing 1-piece rotors.
The link in post#2 has your options. They have 2 piece rotors, you don't have to buy stainless steel lines and have choice of pads. I tried doing what you are trying to do (piece together). Came up short. Ended up buying the whole kit from them. Great service
why you'd not spend an extra hundo on the stainless lines confuses me.
Originally Posted by davidv
(Post 9594444)
I think you got everything. If 1-piece rotors do not suit your needs what are you pricing 1-piece rotors.
Originally Posted by beezee
(Post 9594511)
Originally Posted by lgear080
(Post 9594580)
Here's a list with good Nissan Part Numbers for the kit. Format below is Qty, Part Number, Description. Part Number in () is for the optional red anniversary calipers. The spring clips are included with the factory brake pad set. The last item is optional and two last items are from Concept Z performance. Here's my disclaimer...Please verify part numbers before you order! Not responsible for any errors.
1, 41001-1EA1B, CALIPER ASSY-FRONT RH,W/O PADS OR SHIMS, BLACK (41001-1EA4B, RED) 1, 41011-1EA1B, CALIPER ASSY-FRONT LH,W/O PADS OR SHIMS, BLACK (41011-1EA4B, RED) 1, D1080-JL00A, HARDWARE KIT-FRONT DISC BRAKE PAD 1, D1060-JL00J, FRONT BRAKE PAD SET 4, 41217-JL00A, PIN 2, 40206-JL00A, FRONT BRAKE ROTOR 1, 44001-1EA1A, CALIPER ASSY-REAR RH,W/O PADS OR SHIMS, BLACK (44001-1EA4A, RED) 1, 44011-1EA1A, CALIPER ASSY-REAR LH,W/O PADS OR SHIMS, BLACK (44011-1EA4A, RED) 1, D4080-JL00A, HARDWARE KIT-REAR DISC BRAKE PAD 1, D4060-JL00J, REAR BRAKE PAD SET 4, 44217-JL00A, PIN-PAD 2, 43206-JL00A, ROTOR-DISC BRAKE,REAR 1, 350Z-41G37-VP100, CZP 350Z Akebono Bracket Adapter Kit 03-08 1, 350Z-NIS-1335, CZP 350Z Teflon Coated Stainless Steel Brake Lines 03-08 |
What are you looking for exactly? Why not the wilwood factory kits? One of the vendors here offers a great price on them, the rotors are two piece, and pad selection is abundant for the wilwood calipers. That's the route i'm going very soon.
Originally Posted by heyyouduh
(Post 9603064)
I kinda have to agree with him here. If not the Wilwood kits then at least working with a current supplier who's done the work makes for a simple install and such. Just the shipping alone bringing in a half dozen different suppliers could well offset any price gains. Sure, you'll need new ss hoses with the Wilwoods....they're included..and so what? Bag $20 and some help off a buddy for helping install the new parts. Want to go a bit out of the box? [IMG]http://i122.photobucket.com/albums/o...5/DSC_8887.jpg[/IMG] |
Any thoughts on just doing just the Akebonos on the FRONTS ONLY for an 08 with standard brakes?
Originally Posted by ronn1
(Post 9643922)
(Post 9643933)
I ran Wilwood fronts with 06+ rears for a few months, way to much front bias. It may be possible with OEM rear Brembo though.
Now that you went to all this trouble to price everything needed, lets see the results. Photos appreciated.
Outstanding gonnaget thread!
^^^ you love doing that don't you
^^^ davidv strikes again! :rockout:
