Tokico D-spec w/ Swift spec-R springs, thoughts?
The D-Spec's are on the way. I have Tein S tech springs, but I have had then since 04, and I don't think they lower the front quite as much as I would like. So im in the market for springs. Stiffer and lower springs. Numbers on the Swift Spec-R seem to be perfect. A tad stiffer then the Teins and lower a bit more (.6" Tein vs. 1.2 Swift).
So.... Good to go, or is there a better option spring out there for me? I have done my searching and from what I read I should be gtg. Also, I have RPF1's running R-S3's, Progress sways and GT Spec tie braces. I have a budget, which is why the Tokico over Koni's and im not a huge fan of Coilovers for some weird reason. Everything I do is for the fun factor in this car. Cornering ability makes me smile. I autox, but it's just for fun. I could care less about classes. I'd rather not do too much more as far as alignment parts. I think I can stay within stock specs with this setup, but if need be I guess I can do caber arms. |
I was under the impression you definitely need rear camber arms if the drop is 1.2"
in for the results of this setup... |
Front is 1.2" drop and rear is 1" drop on the swift springs. I don't mind running a bit of camber, but out of spec is not what I want to go.
