rear camber bolts wont come loose
Im trying to install my SPC rear camber kit however even hitting the bolt with a 150 psi impact gun it wont budge. I hit it with some penetrating oil and let it sit for a few minutes with no success. Ive tried hitting both sides on the bolt behind the rotor with a wrech on the other side too
do i need more psi? is my bolts just frozen and ill have to break them off or something? or what? |
Do you have a breaker bar?
break bar if not , drill them out
Yeah breaker bar worked for me theyre on there preety tight
stock arms use a concentric washer that it is keyed to. Tabs hold it in place from rotating.
Try putting your TQ on the nut, not the bolt. |
Cux… based on his description:
Originally Posted by potato
(Post 9651719)
True.
I dont remember any trouble with mine but that was years ago. With the car on jacks you can use the floor jack to lift the wrench on the nut while the bolt is held in place with another wrench that is stopped by the ground. Flip flop for the other side. Be careful you dont lift the car off the stands. hop,you doing any work on your Z? Would like to check it out one day. |
Originally Posted by Cux350z
(Post 9651902)
OP, what brand impact are you trying to use and what is your compressor rated at? hop,you doing any work on your Z? Would like to check it out one day. |
(Post 9651719)
My inlaws have one of these I use & it's a beast. takes off lugs instantly... you have to be careful. If you DO have a good amount of Torque, then yeah... time to get anther bolt & start hacking/drilling it out. Maybe heating it up for a bit with a MAP gas torch would work, but I wouldn't suggest You try that... |
that is what i have and have it all the way up on psi. going to try the breaker bar today along with the jack. i tried the jack last night and i think it actually did start to rotate once my suspension compressed a bit haha
