Will Akebono's clear my XXR's 530's?
I have a couple questions. I'm not very good with this kind of stuff;offsets and what not.
I have XXR 530 18x9.75 all around, I believe +20. I want to get the Akebono BBK. I do a lot of spirited driving and I have read that it's not worth it for extra braking force, but for brake fade. My OEM non-brembos fade very quickly, new pads and fluids and all. Would this Akebono BBK clear? If not, will I need spacers, or will it just not fit an 18"? What rotors should I look into? (Please, I'm on a budget and cannot afford incredibly expensive rotors) Is the Motul fluid the best I could get for the price? Hawk HPS pads? Or some others? I know, there might be topics, please don't flame me. I'm just looking for some help guys. Thanks so much in advance. :) |
I have the Akebonos and there is one thing I can tell you. They are huge. Depending on the wheel design, they may or may not. Best bet is if you get someone with same wheels that has them. They clear MOST 18s but not ALL. The +20 offsets probably will help clear. Motul is popular among members here so I went with that but I am sure there are other equally good ones out there. I went with Hawk HPS to help minimize brake dust and indeed it does help
Here is a link to XXR wheels. You might find one that has same wheels with Akebonos https://my350z.com/forum/wheels-and-...ls-thread.html |
Originally Posted by beezee
(Post 10005059)
Yes. the smaller the offsets the better the chance that they clear. I edited my post with a link that might help. In the worse situation you can use spacers but it is a good idea to buy the right offset wheel to avoid spacers if you can
The easiest way is to print out this Akebono brake template from Concept Z and see if your wheels are touching the paper caliper
http://www.conceptzperformance.com/i...nttemplate.pdf If they are; you either might be able to run a small spacer or you will have to change your wheels to something that has better clearance. |
Got my Akebono set into my mechanic's shop this P.M. so I ran over and we opened the boxes up; sorry no pics, but it's a beautiful kit and the car goes in Mon. A.M.! Got the 40th Ann. red calipers, slotted/drilled Centric rotors, CZP SS lines, Motul fluid, silver billet brackets, Centric posi-quiet pads. Those front calipers are "big" like everyone says, but I have done the template test on a front RPF1 of mine and that cleared on the 18" wheel.
I'll get some good pics of it all soon. |
As Beezee has said, it will clear most 18s but some won't. I had problems with my 18x10+26, it cleared the spokes easily but not the barrel
http://farm9.staticflickr.com/8271/8...77db7a1b_z.jpg Mainly depends on the wheel design itself :) |
^ thanks taryon. Yeah Z1 had emailed me that anything less than +25 offset should clear on the rpf1's; I'm +15 all 4 (18"), but I guess that I'm nervous now that I've bought the kit and about to have the install! Especially when I held that "big" front caliper today haha! I've done all of the checking I think I can and it all sounds good, but you know!
* when I unpacked the first front caliper today my jaw about dropped when I saw how big it looked; I was thinking "is this going to fit"? (I know, that's what "she" said hehe). |
Originally Posted by BigBlue
(Post 10175588)
Did you ever buy the brakes? And did they clear the wheels or no
