Knocking sound coming from brakes after brembo upgrade
on
I just upgraded to oem brembos. But I'm hearing an initial knock sound when I brake. This seems to come from a different wheel each time. It sounds as if the brake pads are popping against the rotor. Usually the first brake I can hear it. I'm going to bleed the calipers this weekend and I feel some play in the pedal. I could be paranoid but the car seems to run differently not sure how, but just the feel. I did a rebuild on the seals and boots, could is have done something wrong? Thanks
on
You nailed it. I went and lubed up all the pins, when I got to the rears the inner pad had a lot of play. Fronts were snugged. I also used a motive bleeder today, but I still have a soft pedal. I'm going to try to trouble shoot some more this weekend and bleed again. I do have Napa ultra pre pads, could that be an issue? If I can't figure this out, the meet can't get here soon enough. I appreciate the help. Thanks
Justin100
11-29-2015 03:58 PM
Dark Knight
Wheels Tires
11-11-2015 08:40 PM
