H&R Coilovers Question
I posted this on another thread but thought i'd just create a new thread for discussion.
I have H&R coilovers. I hate the design of the rear adjustable collar. It is inverted. Meaning the collar is mounted to the spring bucket (bottom of spring). Not like the usual collar mounted on the spring perch (top of spring). I posted on another thread about this noise (scrape or squeak) ive been getting due to the metal to metal contact from said collar and the spring bucket. I was thinking i should just get rid of the set up and go with a Bilstein Shock and aftermarket spring combo. But here's the thing. Ive done some research and it looks like Bilstein is some how incorporated with the design and construction of H&R shocks. So... I was thinking why get rid of these shocks that are designed for lowered vehicles. So im thinking I just keep the H&R shocks and pick up a set of springs for the rear to get rid of the spring and collar. By doing this, I will retain the adjust-ability from the front. So i can correct the rake from the new spring. Have you guys heard of Bilstein and H&R working together? I know both companies are from germany. |
I think most of the stock photos Bilstein is using on their site are generic. Either way they conversion is much easier than buying a whole new setup, just need some adapters and you can convert to 2.5id linear rear spring if you like.
PM user kilogram he recently purchased a set of PSS and they were fresh from Germany, so he should be able to tell you what they employ for their latest rear collar configuration on the Z. https://my350z.com/forum/brakes-and-...-review-3.html |
H&R uses Bilstein damper inserts in most (if not all) of their line. It's just the damper insert.
I ordered a B12 pro kit, not PSS, so I don't have any info on whether they run different rear height adjustment collars from the H&R. Looking at pictures, it appears there's a taper to the rear springs on the H&R. Is it too much to be able to mount the collar on the upper spring mount? If that's not an option, try something like these to replace the H&Rs (Tein rear height adjusters and springs- I'd compare the spring rates and replace if necessary): https://my350z.com/forum/suspension/...ith-parts.html There used to be a few posts that mentioned where to buy the larger diameter height adjustment collars, and you can get larger diameter Eibach springs to suit them from Summit, etc. Per your original question, no- there's no reason you couldn't use a set of standard springs in the rear. You just want to make sure they're within a few % of the H&R rear spring rate. You may have to directly measure that, I can't remember if the rates have ever been published. |
Originally Posted by kilogram
(Post 10589589)
You might be able to call and ask them. I've done that in the past and they were more than willing to tell me spring rates on my suspension.
(Post 10590175)
Here's how the coilovers look. Stole this pic from bmurrays thread. https://cimg7.ibsrv.net/gimg/my350z....291c5f2170.jpg https://cimg0.ibsrv.net/gimg/my350z....88bef907ca.jpg https://cimg1.ibsrv.net/gimg/my350z....e159e24d03.jpg |
Maybe buy some new spring mounts and cut them off to make a nub like what's in the bottom of the bucket for them to seat on. Rubber cuts easily. I don't know what that area looks like without the spring mount in place so take that with a grain of salt.. There should be a way to attach it though, that's how other kits do it.
Silicon or some other adhesive and make a thin gasket as a noise isolater
I was gonna say rubberized undercoating in the spring bucket, but it sounds like the problem is half noise, half just being a general b*tch to adjust.
I'd try solving the noise issue first. I have these coilovers and yeah, adjusting the rear is a royal pain in the ass, but mine don't make any noises even with the metal on metal contact in the spring bucket. If I were you I'd buy some thin rubber matting, place it over the protrusion in the spring bucket with some adhesive and cut the rubber with an exacto knife around the protrusion, leaving a secure rubber layer between the perch and spring bucket.
Late update. Coilovers have been sold. Noise was coming from rear shock top mount not the coilover. Took top mount off. Cleaned it sprayed it with lithium grease and noise was gone.
