Do OEM 04 G35 Brembo Calipers fit the 07 350z enthusiastic?
Hello everyone,
I have a 07 350z Enthusiastic on hand. These days, I'm trying to find a set of Brembo Breaking Calipers which comes with the Grand Tour and Nismo version. I found one set of Brembo caliper which was donated by a 04 Infinite G35. Like this~ https://cimg9.ibsrv.net/gimg/my350z....c515e1b52f.jpg May I ask if this set of Brembo will fit my 07 350Z 6MT? |
They'll fit the rear. You'll need to cut the lip off the dust shields, and you'll need the proper bolts from Nissan.
eDIT: you need the larger Brembo rotors, too. |
Originally Posted by dcains
(Post 10668782)
If the fronts came off a G35 they'll fit. You need the larger rotors, but you can use the same bolts and don't have to cut the dust shields.
There is a thread on this site about the conversion - search for it and read it before you do the work. |
(Post 10668865)
The Brembo calipers on the G35 and 340Z are exactly the same.
Just did this swap
I just moved my brenbos from my G to my Z you'll need the larger rotors, stoptech makes a kit with awesome braided lines and slotted rotors w new pads, PS the bolts are not the same from the brenbo caliper to the Nissan calliper the brenbo is a courser thread I lost one and ended up having to go to the dealer to get a new bolt, great fun and easy mod, enjoy!
The front bolts are the same, but the rears are not.
