Spacers making Steering Wheel Shake?
factory torque spec at 85 is typical for many vehicles but I'm wondering, would the proper torque change if different wheels or lug nuts were used? I notice on some Toyota trucks that come with an option of steel or aluminum wheels the recommended torque is different by like 40 ft-lbs depending on which factory wheels it has.
350Z/370Z Tech Moderator
That, and the fact that the determining factors for "required torque" lay equally in the fastening gear (lug nuts, studs) and what they're fastening to (hub) as much as to the wheel itself.
But interesting... maybe one of our resident tire tech people can shed some more appropriate light on this?
That's actually quite a good question. What we did in the shop was look up the specs for each car that happened to be on the rack and went according to what the DB told us. In this case, I'd venture to say that it's going to be the same for any wheel bolted up to a Z since ALL Z wheels were/are aluminum.
