Air coming out of bleeder valve after closed (brake flush)
Hey guys,
I just installed SS brake lines on my '03 non-brembo 350z. Obviously it requires me to bleed the brakes to get the air out. I followed the '03 FSM for bleeding brakes. Bleeding was no problem but, the pass. rear and driver front has air seeping out of the bleeder valve once I closed it.
I used about 2 bottles of fluid to flush, but still having that issue. I pumped the brakes (while engine off) and the pedal was stiff after 3 pumps. However when I drove the car, the pedal turned out to be slightly squishy (still able to stop when I need to) but I thought the pedal would be stiff with the SS brake lines.
Anyone have/had this issue? Any solutions?
Thanks
Thanks
By air, I assume you mean fluid.
Often the nipples will weep after install making it look like a leak.
If not, then either they arent closed tight enough, or they are stripped and wont get tight enough. Clean the area with some brake cleaner and cycle the pedal and re-check to make sure they are actually leaking.
Dont expect wonders from the SS lines, they definitely wont change much.
bebot93 (06-10-2017)
hi so after rebuilding used brembos and installing and bleeding myself...
it's either:
A. You still have air in your system, I would invest in a motive power bleeder...but it's possible without...just make sure to have another person help and tap the calipers to get air bubbles out. I did not have much success trying three times with someone helping me. Bought a motive power bleeder and worked perfectly first try.
B. What guitman32 said
it's either:
bebot93 (06-13-2017)
