Banging noise
Hello i am very new to this forum i have a fairlady z nismo and i have started to hear a lous banging like a ball joint or something is away but it aint that it passed an m.o.t guy says no fault. Anyway trying to figure what it can be and now my power steering is playing up (heavy steering) and also still banging noise was wonder if anyone can shine some light for me ave narrowed it down to the steering colum that may be goosed would this cause a clunking noise and also make me have heavy steering or can it be something else am.lost here as cannot see any issues with the suspention anywhere at all.
thanks for reading gary |
Umm..............Huh?......So you want to know where the CLUNK is coming from?
You also want to know why you have stiff steering? |
Yes as it started clunking then the steering became very heavy when driving it has fluid in it so no leaks in the power steering
My guess the tech that did your "Saftey check" missed something.Happens ALL the time unfortunately.Check the balljoint attached to the tension arm.You won't feel
the play in them when you shake the wheel side to side and up and down. Stiff steering was a sudden thing?. |
No happened couple of days after the clunking noises.
i will change the ball joints and see if the noise goes away but could that cause stiff steering!! |
Originally Posted by Gazza
(Post 10944702)
i will change the ball joints and see if the noise goes away but could that cause stiff steering!! Check for play in the ball joints,Also the front sway bar end links for play too.For the clunk noise..... The stiff steering could be caused by a seized intermediate shaft u joint or a faulty power steering pump.Blockage in the lines. Does the pump whine at all/is it noisy?. Does it have any assisted steering at all or does it have the same stiffness even when the car is off? When you're turning your steering wheel is it the same stiffness the whole time Or does it get stiff then easier then stiff again as your turn the wheel? |
Yes it gets stiff then easy then stiff again when driving pump doesnt whine at all sway bar is a good shout as cant really see it to well for the undertray being in the way am hoping its nothing too major when i get properly under there the car has only fone 34000 miles so not bad for 11 year old i have driving it nearly every day since the last 2 years
(Post 10944709)
Ok i will give that a try aswell while am under there tommorow i will get back to you if i find ny faults you have sayed about
thank you for your help gary |
Good advice, but I think the OP needs a good shop :icon44:
(Post 10944716)
