SPL Midlinks and Ohlins DFV
The spring bucket on the SPL midlinks (for if you want to maintain OEM rear suspension setup) cannot accommodate the rear springs in the Ohlins DFV package.
The OD of the springs is greater than the OD of the bucket. I want the OEM setup but want to lock out the eccentric washers and keep some adjustability, so I'll likely be going with swift springs which will definitely fit the midlink. Just posting as an FYI since I did not come across much in research/101s here. -Matt |
