Stiff Brake Pedal
Hi guys!
I am new to the forums. We have had a 350z for a while, however, my girlfriend is getting a new Focus ST and has relinquished control of the Z to me. I have plans to look into some autocross and drift fun with it. however, first I want to fix some small issues that the car has, which is the reason for this post. The brake pedal switch had broken on it some time ago. While I was fixing it, I needed the pedal suppressed, so I decided (probably not the smartest decision) to put a stick against the pedal and the seat to push it down enough for me to arrange fixing the switch. After that, the pedal has been very stiff ever since. I was told it could be the brake booster, so I did the check for that where you pump the brakes and start the engine. By that test, it is okay. I wanted to reach out to this forum and see if there's any pointers you guys could give of things I should try? Thanks for reading! |
