Which Brembo Track Carbotech Pads
From searching it looks like most circuit racers here are using a combination of XP10 front, XP8 rear. However Carbotech list XP10 F, XP12 R for Brembo calipers so I'm wondering if anyone has tried that combination and what the results were.
Id stick with 12/12 square. I dont think a front stagger is necessary or beneficial. Ive gone through a number of sets of Carbotech, and if you run a staggered compound your fronts will last even less time. Not shifting the bias forward will lower the wear rate on your fronts. I ran a set of xp20s before I left the brand and it was too much.
I use DTC all around. Performance is great, contingency is also great. They are relatively hard on rotors, so people who use expensive rotors tend to be left with a sour taste after a few sets. But I was left with a sour taste with Carbotech after using enough to realize that their wear rate is below average.
I put DCT-70's F&R on just recently (and swap out for road pads after track), these are amazing so far. The weak link are tyres with them !
RobPhoboS (05-14-2019)
