MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Brakes & Suspension (https://my350z.com/forum/brakes-and-suspension-399/)
-   -   Jason's Z Meets Eibach... (https://my350z.com/forum/brakes-and-suspension/64091-jasons-z-meets-eibach.html)
Jason@Performance Mar 6, 2004 01:04 PM
1 Attachment(s)
So since my car is going to be at Hot Import Nights tonight. Yesturday I decided to throw some Eibach's on to get rid of my wheel gap. And of course this makes a perfect oppertunity to take a good before and after shot as well as offer a limited time special on Eibach 350z Coupe Springs for $202.02.
I have 31000 miles on my Z. So the stock springs have settled in a bit so it sits slightly lower then most stock Z's...
How do they feel. My Z with the stock springs was bouncy, lots of body roll on turns, and every little bump you hit you really felt. With the EIBACH's the car sits lower, less body roll, and those little bumps are barely noticed and there is no more freeway bounce. It really is amazing at how just changing the springs on this car even to TEIN or Other Spring / Coil over systems makes such a huge difference.
Here is a before shot (morning before changing springs...
Jason@Performance Mar 6, 2004 01:06 PM
Re: Jason's Z Meets Eibach...
1 Attachment(s)
With Eibach's driven around for about 20 minutes.... Eibach's will settle unlike tein's which are guarranteed not to settle...
Reggi914 Mar 6, 2004 01:21 PM
Looks great!
ZRAYGO Mar 6, 2004 01:25 PM
Looks good jason, I have an off topic question. How do I get a picture onthe bottom or above my signature? Kind of liek you have the Performance Nissan banner below yours? Is that possible for a member or do you have to be a vendor?
Jason@Performance Mar 6, 2004 01:27 PM
in your sig... type (remove the * ) [*img]http://picture.url[/*img]
ZRAYGO Mar 6, 2004 01:32 PM
what happens after that?
Jason@Performance Mar 6, 2004 01:34 PM
then your photo will be added...
like adding a photo to a post...
remove * [*img]http://members.aol.com/performancenismo/cfnismo4.jpg[/*img]
will make
ZRAYGO Mar 6, 2004 01:36 PM
I must be retarded or something.....but could you add my pic of my car. its on the IT HAS BEGUN (PT2) POST. THE FIRST PIC. THANKS.
Jason@Performance Mar 6, 2004 02:00 PM
if you send me a URL to your picture posted somewhere on the net I will email you the code you need...
but I dont have any place I can host an image for you sorry :(
aproy Mar 6, 2004 02:04 PM
way to hijack a thread!
i need some springs.
Jason@Performance Mar 6, 2004 02:40 PM
well I got eibach's at $202.02 special price... Normally 249.95...
place an order on our web site and put in the comments section you are a my350z member :)
chattermark Mar 7, 2004 04:39 PM
When you change the springs, do you have any alignment problems? DId you realign? Camber issues?
1337 Mar 7, 2004 04:45 PM
How would you compare Eibach vs Nismo
Sevs2k Mar 7, 2004 04:46 PM
I will second everything that Jason said.
I just slapped on some eibachs.
Makes the car ride smoother, flatter and the bounce is gone. It looks much better too.
Worth every penny.
Sharif@Forged Mar 7, 2004 05:17 PM
I did the same thing...bounce is totally gone. Mario drove my car and can attest to that. The only thing I dislike is that the initial action of the suspension is too soft for my taste....so that inital turn-in is kinda vague. But they tighten up really nicely once you enter the turn. I guess that's the trade-off. :D
Jason@Performance Mar 7, 2004 06:03 PM
Alignment... hrmm... well... It drove straight so I said forget the alignment I gotta get to Roll In.. HAHA...
But by the looks of it... Rear camber looks the same as Jeff's with the Nismo S-Tune... The car doesnt pull left or to the right, jus goes straight... Took it on some twisties today... Im happy with it...
For now, These springs got me even happier then I was with the car then before... Next (when I get money) ((which wont be for a long time)) comes rear camber and toe rods, our upper control arms, and full slam with ____________ suspension... I havent decided who's coil over to use yet... By this time I will need to replace my shocks any way.. I now have 31500 miles on my Z33...
Sevs2k Mar 7, 2004 06:38 PM
Progressive springs= soft at turn in, unless you get progressive springs that are extremely stiff...
That can also be solved by getting some stiffer sidewalled tires, R compounds or bigger mags/less tire...
No matter what, I see the eibachs as a positive no matter how I look at them
Welsh 350Z N Mar 8, 2004 10:44 AM
Is there any issue fitting these (or any) springs to a Track model with stock shocks ? I wondering if there's any impact on VDC or anything ?
Jason@Performance Mar 8, 2004 10:48 AM
no issue...
I have VDC and am running the springs and the nismo wheels...
Just use the sugested tire size for the wheels...
any suspension and sway will work with VDC
Welsh 350Z N Mar 8, 2004 12:55 PM
Thanks. I just remember that the Nismo coilovers and sway bars are stated as "NOT to be used with VDC" ??? Would I have to change tire size from stock Track ?
