Brake dust stains on wheels??
Old Nov 28, 2006 | 09:57 AM
eze-edsel's Avatar
eze-edsel
Default Brake dust stains on wheels??
Does anyone know a good product that removes brake dust stains on after market wheels(Axis Hiros)? Any help would be greatly appreciated.
Old Nov 28, 2006 | 09:59 AM
Brick-Z's Avatar
Brick-Z
New brake pads
Old Nov 28, 2006 | 10:13 AM
Soap and water.
Old Nov 28, 2006 | 10:42 AM
eze-edsel's Avatar
eze-edsel
Ok first off I asked for help. And second I said they were stained not just brake dust from normal wear. And if you don't have any information that can help me then DON'T reply to the post.
Old Nov 28, 2006 | 10:48 AM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
I used to get them on my G35 wheels. I never could get them off. But I only used soap and water, I was too worried about damaging the clearcoat to use anything else.
Any pics of the stains?
Old Nov 28, 2006 | 10:52 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by davidv
Soap and water.
+1
Old Nov 28, 2006 | 10:54 AM
Vader007's Avatar
Vader007
There are a couple of things you can try,
Claybar, 50/50 mix of simple green and water, P21 wheel cleaner, wheel wax used as a cleaner!
Hope this helps.
Old Nov 28, 2006 | 11:02 AM
eze-edsel's Avatar
eze-edsel
Thanks for the helpful info guys. I will post pictures of the stains as soon as I get home from work.
Old Nov 28, 2006 | 11:03 AM
eze-edsel's Avatar
eze-edsel
Hope this helps.
Which one would work the best without damaging the clearcoat?
Old Nov 28, 2006 | 11:05 AM
Steve-O Z33's Avatar
Steve-O Z33
Get a soft brush and some Meguiar's Hot Rims. Let the Hot Rims sit on the stains for a few. Spray the brush with water. Shake the brush and spray it with the Hot Rims. Scrub away. If that doesn't work, try wet sanding.
Old Nov 28, 2006 | 11:07 AM
Vader007's Avatar
Vader007
In order I would try clay bar, wheel wax, P21 then simple green.
I have used all of these effectively on my Volk's!
Old Nov 28, 2006 | 12:09 PM
VO...'s Avatar
VO...
Administrator
Got a question for you.
Are trying to clean away normal brake dust or are you trying to take off some stained brakedust that wouldn't wash away with regular soap and water?
Old Nov 28, 2006 | 12:14 PM
eze-edsel's Avatar
eze-edsel
Brake dust stain that does not come off with regular soap and water.
Old Nov 28, 2006 | 12:24 PM
zand02max's Avatar
zand02max
Thats why you have to get the brake dust off as soon as possible. How long did you wait for it too sit like that?
In order for this too not happen again, you have to change the brake pads to lets say Hawks, then your problem is solved.
Also use Wheelwax once you get the brake dust off.
Your just lucky its not on custom wheels!
Old Nov 28, 2006 | 03:10 PM
VO...'s Avatar
VO...
Administrator
Then in that case, use either regular car wax of the clay bar.
Obadabot
Jun 18, 2023 11:31 PM
