MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Cleaning & Detailing (https://my350z.com/forum/cleaning-and-detailing-22/)
-   -   Removing Zaino's (https://my350z.com/forum/cleaning-and-detailing/392899-removing-zainos.html)
wilson7136 Oct 17, 2008 04:15 PM
Removing Zaino's
Hello,
I wished I had purchased my pc before I applied my multi coats of Zainos. I think I have covered over my swirls instead of removing them first. Any thougths on removing the Zainos and starting over? I thought I had read somewhere that you could use rubbing alcohol? No mention was made as to how much to use or how long to leave it on. Car is Redline with 4-5 coats.
Thanks in advance.
Wilson7136
Fallen612 Oct 17, 2008 04:31 PM
i would try to wash the car with warm water and dishwater detergent. its suppose to get the wax off. just never wash the car with dishwater detergent after that. or you will havce no more wax.
DavesZ#3 Oct 17, 2008 04:32 PM
Alcohol will remove it but it's not necessary if you plan on machine polishing - that will strip everything off.
It might be easier to get some Z-PC and use it. It will leave the surface ready for reapplication of Zaino.
DavesZ#3 Oct 17, 2008 04:33 PM
Unless you wash it multiple times, even dishwashing detergent won't strip Zaino. The purpose of using Dawn to wash a car is to strip waxes and mainly grease. Zaino is not technically a "wax" but a polymer.
davidv Oct 17, 2008 05:36 PM
Polish removes old wax.
TreeFiddyZee Oct 17, 2008 08:39 PM
I wouldn't recommend alcohol. I mistakenly used it when I changed an emblem and it removed some of my paint. Alcohol also has an extreme drying effect, which would probably cause accelerated paint failure.
415mm Oct 20, 2008 12:41 PM
If you intend to use alcohol make sure you dilute it 50:50 ....alcohol : H2O
matix101vz Oct 20, 2008 12:45 PM
call up zaino and ask them, they are very very helpful.
matix101vz Oct 20, 2008 12:46 PM
i have been using zaino for a while, best products i ever used
