2005 350Z ST3 Racecar
7 Attachment(s)
Hi all,
I am floating the idea of moving on to other classes, so I have my Zed up for sale. Here are the details: Never wrecked, it is currently setup for NASA ST3. Original owner since taking delivery in July 2005. Maintained and built by Japtrix/Pros Tuning in West Palm Beach, FL. Additional photos or info available by calling 954-732-6426 or emailing me at obzezzed350@gmail.com. Price is 35k. Overview: - 5 Hours on built engine, 314whp, 284tq on E85 - 5 Hours on new OEM 6 speed transmission - 3218 lbs with 190lb driver, and 3/4 tank of fuel - Turn key w/ Traqmate, Cool Shirt included. - 2 sets of Enkei RPF1s (18x9.5) - NASA/SCCA Logbooks Engine: - 13:1 Compression w/ CP Pistons, Carillo Rods - JWT S7 Cams, Ferrera Valves - 3 angle valve job - 7500RPM redline - Haltech ECU paired with Uprev Flash - Motodyne Plenum Spacer - NWP 75mm throttle body - Custom intake/exhaust - Crawford Headers - Spare block and 6 speed included - Oil cooler - Koyo Radiator - Fuel transfer pump in tank to allow car to run under 1 gallon. Drivetrain: - OS Giken single disk clutch - OS Giken LSD - SPL differential bushings - Differential cooler Suspension/Brakes: - Custom valved JIC FLT Dampers - 20kg F/ 12kg R spring rates - Stoptech ST40 Front BBK - OEM Brembo Rear Brakes - SPL upper a-arms - SPL compression bushings - SPL rear camber links - SPL rear midlinks - SPL lockout kit - SPL bumpsteer kit Chassis/Body - Fulcrum Aeroworks front splitter w/ belly tray - Fulcrum Aeroworks 71" rear wing, 14" chord - Seibon Carbon rear hatch - Racing Shields rear lexan window Safety - Mesh window net - Schroth belts through 2020 - Sparco Pro-ADV seat - Cage w/ NASCAR bars driver side - Fire system w/ 3 nozzles |
This car is very well prepared and is a performer, very fast. Sad to see it for sale, but good luck J.
What class would this Z race in SCCA?
Originally Posted by dkmura
(Post 10651052)
