bryan@Z1 |
04-09-2010 07:27 AM |
Z1 Mild Performance Clutch Kits In Stock
This is the newest offering in our line up of clutches for your 350Z / G35 application. The new Z1 Mild Performance Clutch kit fills the void for cars that need a slightly stronger clutch than stock but not quite the increase that our Street Performance clutches offer.
This kit uses a pressure plate with OEM spec clamping force so that pedal feel and pressure remains the same as stock, this plate is paired with an upgraded disc to provide an excellent working and performing clutch kit for daily driven cars.
This kit is not for use with forced induction and is recommended for cars producing 350 HP or less.
Will not fit 07+ HR (Dual Throttle Body) Engines.
We've been running this clutch in our G35 for over 2 years now and it has been flawless, multiple track days, road trips, Tail of the Dragon runs, and Atlanta traffic have all been thrown at it and it continues to perform.
The kit includes: OEM Spec Pressure Plate Assembly / Upgraded Steel-Back High Brass clutch disc / OEM Spec release bearing / OEM Spec Pilot Bushing / Clutch Alignment Tool.
The option is available to add a SS Clutch Line or upgrade to a Nismo Roller Pilot Bearing.
Click Here To Order Yours Today. $279.00
