Southbend Clutch/Flywheel Combo + Free Bonus Parts, $1 Shipping, NO CHATTER!!! :)
New Southbend Flywheel are designed to replace the OEM Dual Mass flywheel. These flywheels also do not chatter like aluminum flywheels, and you still get a weight savings of 5lbs. This Solid Piece 4140 Billet Steel is very durable, and can take a beating from Puck clutches. Total weight including ring gear is 24lbs.
Southbend Clutches come in a variety of TQ Specs, so there is a Clutch out there for everybody. Stage 1-3 are OEM if not lighter feel, stage 4-5 are going to come with a SS pressure plate, and are slightly heavier then stage 1-3, but I could barely feel the pressure difference. *Each Kit comes with Chromoly Pivot Ball, Stainless Steel Clutch Line, and Pilot Needle Bearing. Shipping is $1 for 3day Service* _________________________ Southbend 350Z Combo Stage 1 (435 TQ) Rally Clutch / Flywheel Combo http://www.conceptzperformance.com/C...ages/4447l.jpg _________________________ Southbend 350Z Combo Stage 2 (486 TQ) TZ Clutch / Flywheel http://www.conceptzperformance.com/C...ages/4448l.jpg _________________________ Southbend 350Z Combo Stage 3 (530 TQ) OFE Clutch / Flywheel http://www.conceptzperformance.com/C...ages/4449l.jpg _________________________ Southbend 350Z Combo Stage 4 (650 TQ) OFE-SS Clutch / Flywheel http://www.conceptzperformance.com/C...ages/4450l.jpg _________________________ Southbend 350Z Combo Stage 5 (800TQ) FE Clutch / Flywheel http://www.conceptzperformance.com/C...ages/4451l.jpg _________________________ Southbend 350Z Combo Stage 5 (763 TQ) DXD-B Ceramic 6-Puck Clutch / Flywheel http://www.conceptzperformance.com/C...ages/4596l.jpg _________________________ Southbend 350Z Combo Stage 5 (825 TQ) DXD-F Feramic 6-Puck Clutch / Flywheel http://www.conceptzperformance.com/C...ages/4511l.jpg _________________________ Redline MT-85 (4-Pack) - 350Z, $43.20 http://www.conceptzperformance.com/Cart/images/517l.jpg Description: Recommended for Nissan 350Z, 370Z, G35, and G37 * Safe for brass synchros, as it lacks the reactive sulfurs found in most GL-5 oils that cause damage * Offers quicker shifts, perfect synchronizer coefficient of friction * Eliminates notchy shifting, even when cold * High performance gear protection and longer synchro life * Recommended for GL-1, GL-3 and GL-4 applications, as well as where most special synchromesh fluids are specified * Satisfies the gear oil viscosity requirements of 75W, 80W, 85W and motor oil viscosities of SAE 30 and 5W30. Includes 4 Quarts to complete the Job _________________________ Nissan OEM 350Z Rear Main Seal https://conceptzperformance.com/item...dium/image.jpg Description: This is a great time to replace your rear main seal, saves time and money if your rear main seal decides to leak after you finish your clutch install. _________________________ We also have Southbend Clutch Combos with Fidanza Light Weight Flywheels: Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - Rally Series (435 TQ Cap) http://www.czp.us/Cart/images/2296l.jpg _________________________ Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - TZ Series (486 TQ Cap) http://www.czp.us/Cart/images/2298l.jpg _________________________ Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - OFE Stage 3 (530 TQ Cap) http://www.czp.us/Cart/images/2300l.jpg _________________________ Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - OFE Stage 4 SS (650 TQ Cap) http://www.czp.us/Cart/images/2302l.jpg _________________________ Southbend / Fidanza 350Z/G35 DXD Clutch/Flywheel Combo - FE Stage 5 SS (800 TQ Cap) http://www.czp.us/Cart/images/2304l.jpg _________________________ |
Bump
Bump!
Bumped!!
Bumped!!
stg2 shipped to new york 12 919. I don't need the flywheel but i would like all the bonus with it.
PM Sent
Bumped!!
Bumped
Bumped!!
Bumped
Bumped!!
Bump!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
Bumped!!
