Z1 Motorsports: Clutch Concentric Slave Cylinder Elimination Kit
Old 10-28-2015, 12:07 PM
  #101
Rev_Night
Rev_Night's Avatar
This threaded rod, this is on the black cylinder that is now outside the tranny? How can I tell by driving my car, or looking at this rod, that an adjustment is needed?
Dumb question, but I assume the Wilwood HD MC will work with your CSC just fine?
Rev_Night is offline
Old 11-05-2015, 07:04 AM
  #102
Z1Motorsports
Z1Motorsports's Avatar
You will not need to make this adjustment much at all. You will notice a little more then the usual dead pedal. The clutch will need to be adjusted slightly to regain it's appropriate amount of dead pedal.
Z1Motorsports is offline
Old 11-05-2015, 09:39 AM
  #103
Rev_Night
Rev_Night's Avatar
The clutch will need to be adjusted? So the clutch threaded rod that goes to the clevis fork? Which way does it need to be adjusted, threaded up or down?
Old 11-06-2015, 04:45 AM
  #104
Z1Motorsports
The Slave cylinder normally needs to be adjusted to the proper length. The adjustment depends on the measurements taken. Be sure to check out step 14 page 13 in the instruction manual for more info(trouble shooting guide on page 17). Also if you come to a stand still please give us a call.
El gurple (03-06-2016)
Old 11-16-2015, 05:58 AM
  #105
Z1Motorsports
In Stock!
Old 12-04-2015, 08:23 AM
  #106
Z1Motorsports
Bump
Old 12-11-2015, 07:42 AM
  #107
Z1Motorsports
In Stock!
Old 01-04-2016, 06:15 AM
  #108
Z1Motorsports
In stock
Old 01-19-2016, 06:43 AM
  #109
Z1Motorsports
Bump
Old 03-28-2016, 01:44 PM
  #110
Z1Motorsports
Old 06-01-2016, 11:19 AM
  #111
Z1Motorsports
Bump
Old 06-15-2016, 07:33 AM
  #112
Z1Motorsports
This Z1 350z HR CSC kit is used in street cars, track cars, and competition racing all over the world.
Old 07-17-2016, 07:44 PM
  #113
roninx5x
roninx5x's Avatar
Long time customer of Z1. You guys have done great work on my 2003 350Z, 2008 Infiniti G37 S, and hoping you will work on my new 2008 350Z!
I saw you mentioned discounts when ordering clutch/flywheel in addition to this CSC elimination mod. Can you PM me details? Thinking JWT unless you guys suggest something else. I would also go to your shop to get it installed. BTW - is it safe to drive to your shop from Atlanta? My CSC gave out tonight and I was able to make it back home but have never experienced anything like this before, so a little unsure about highway driving.
Car supposedly makes 300hp at the wheels after being (supposedly) tuned, if that helps with clutch/flywheel suggestions.
Would also want to buy/do:
- UHP rear hatch things
- Lightweight crank pulley
- Complete system fluid change
roninx5x is offline
Old 07-18-2016, 04:40 AM
  #114
Z1Motorsports
Certainly
Sending you a PM
Old 07-18-2016, 11:45 AM
  #115
roninx5x
roninx5x's Avatar
Replied to PM!
roninx5x is offline
Old 07-27-2016, 11:05 AM
  #116
Z1Motorsports
Bump
Old 08-15-2016, 06:42 AM
  #117
Z1Motorsports
Avoid any issues leaving you on the side of the road due to the OEM slave failing one your 370z by installing the Z1 CSC elimination kit. Give us a call 770-838-7777
Old 08-24-2016, 10:31 AM
  #118
Z1Motorsports
Old 09-01-2016, 07:00 AM
  #119
Z1Motorsports
In stock
Old 01-27-2017, 06:28 AM
  #120
Z1Motorsports
Thanks for the orders guys!
07ZEKE
08-23-2021 09:15 PM
sherm
04-11-2020 05:21 PM
EnjukuRacing
09-30-2015 06:55 AM
Quick Reply: Z1 Motorsports: Clutch Concentric Slave Cylinder Elimination Kit
