FS: Z1 Motorsports: High Capacity Differential Covers and Full Diff Upgrades
Old 01-21-2016, 01:37 PM
Z1Motorsports
Z1Motorsports's Avatar
Default Z1 Motorsports: High Capacity Differential Covers and Full Diff Upgrades
Z1 Motorsports 350Z / G35 High Capacity Differential Cover Kit
Z1 Motorsports High Capacity Differential Cover for your Nissan 350Z or Infiniti G35.
Excess heat inside the differential case can lead to premature failure of every component, especially the factory viscous differential which also becomes less effective at higher temperatures. Not only does the heat damage the internal components, but often times we have found the factory and aftermarket differential bushings melted. A good way to combat temperatures inside the differential is to get the heat outside. This finned differential cover acts as a heat sink which allows the heat that builds up in the fluid to be transferred to the cast aluminum cover where the heat can be released through the integrated fins by air rushing over them.
For More Info & Ordering Please Click Here!
Z1 Final Drive Differential Upgrade Kit
Z1's Final Drive Differential Upgrade Kit includes everything you need to change your Final Drive Gear Ratio and Upgrade / Update your rear differential. If you are going to remove the differential why not only do it once.
Final Drive Gear Set
For those of you looking for increased performance off the line we now offer this Nissan OEM final drive ring and pinion gear set. These gears will fit 03+ model differentials, manual transmission model cars only, and will increase acceleration. This of course comes at a trade off of higher cruise speed RPM and decreased fuel mileage.
Starting At $998!
Nismo Differential Cover Upgrade
NISMO Differential Cover for all 03+ Nissan 350Z's, 370Z's, Infiniti G35's, & G37's.
This differential cover features a unique finned heat sink casting that helps dissipate the heat generated under extreme driving conditions. Perfect for any Z/G that has either serious power upgrades and/or sees track time or extended periods of hard driving.
Consider this as an added piece of security for your differential!
Place Your Order Here!
OS Giken Super Lock Limited Slip Differential (LSD)
The OS Super Lock LSD is the culmination of over four years of extensive research and development that led to a revolutionary LSD design with the capacity to house an unprecedented number of friction plates (up to 28 plates in total). Combined with our patented lock timing system, the Super Lock LSD is able to achieve complete lock in a progressive, smooth, and quiet manner, making it suitable for both street and racing performance.
For Ordering Info Click Here!
Tomei Technical Trax Limited Slip Differential (LSD)
Tomei’s Technical Trax LSD is a 1.5 or 2 way version depending on the current differential case in your vehicle and the options you choose. This Limited Slip Differential provides the maximum power transfer to the ground. This is very important for high powered Front engine Rear drive configured vehicles, as much of the power is lost without an LSD.
Staring at $898
For All Z1 Diff Products Click Here!
Z1Motorsports is offline
Old 01-22-2016, 11:18 PM
06platinumG
06platinumG's Avatar
Will your high capacity differential cover fit a G35 with RWS?
06platinumG is offline
Old 01-25-2016, 05:12 AM
Z1Motorsports
It does not fit RAS!
Old 01-25-2016, 02:53 PM
1104's Avatar
Your box is full.
1104 is offline
Old 01-26-2016, 11:35 AM
Z1Motorsports
Originally Posted by 1104
Your box is full.
Cleared and quote sent.
Old 01-28-2016, 11:31 AM
Z1Motorsports
Thanks for the order guys.
Old 02-05-2016, 09:00 AM
Z1Motorsports
Don't forget to get one of these to install during that winter season build!
Old 04-04-2016, 07:00 AM
Z1Motorsports
Thanks for all the orders guys.
Old 05-11-2016, 08:51 AM
Z1Motorsports
Bump
Old 06-15-2016, 07:30 AM
Z1Motorsports
Here is our updated version of the Z1 350z diff kit with the Z1 diff cover.
Old 07-13-2016, 12:18 PM
Z1Motorsports
Bump
Old 08-29-2016, 07:22 AM
Z1Motorsports
In stock
Old 10-28-2016, 12:15 PM
Z1Motorsports
Old 12-20-2016, 01:59 PM
Z1Motorsports
Old 01-05-2017, 06:32 AM
Z1Motorsports
Matt's 350z with the Z1 diff package.
Old 03-14-2017, 01:47 PM
Z1Motorsports
One of the best upgrades for your 350z
Old 03-15-2017, 04:47 PM
transamnut
transamnut's Avatar
Can you get me a price for a Z1 rear differential cover for a 2005 35th anniversary shipped to 53214?
THX!!!
transamnut is offline
Old 05-18-2017, 04:09 PM
LAKERSFAN
LAKERSFAN's Avatar
Installing the breather tube is a mother f!@$er!!!
LAKERSFAN is offline
Old 05-25-2017, 11:37 AM
Z1Motorsports
Lol, It's take some finessing.
Old 09-08-2017, 06:10 PM
Infamous_Z
Infamous_Z's Avatar
Pm Z1 diff cover and Z1 Motorsports Zino Wrist Band Shipped to 60452
-Hector
Infamous_Z is offline
