Winter Tire Size?
on
Winter Tire Size?
What size of winter tire should we get?
Stock have front 225/45/18 rear 245/45/18. I am going with 17" steelies, and it works out to be front 225/50/17 and rear 225/55/17 so the overall diameter will be the same. But I called few tire shops and they said most of the time people use the same size all around. One shop suggested 225/50/17 all around and the other said 225/55/17 all around. What do you guys think? Will I have any problem with TCS or VDC if I have the same size all around? Any input is greatly appreciated, thanks in advance!
When i was in your shoes I searched and found this..
https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
^I would suggest you read that.
When I narrowed it down to size 18', I decided to stick with stock numbers.
225/45/18. 245/45/18.
But with 17's I would have used.
225/50/17, 245/50/17
But you decide what you think is right after reading that post.
R350z
R350z
I run 215/65/16 Blizzaks all round on steelies.
Go to your Infiniti dealership for a wheel/tire packaged they use for the G35 coupe. Great price and functional - all you need for winter. ;-)
on
I dont think 16s wil work on 2006's...the brakes are larger.
However to answer the original poster...I was in the same boat and i ended up getting the proper ratio 225/50/17 front and 225/55/17 rear. I was recommended by the shop to go 225/50/17 all around but i decided not to in the end. I dont think itll mess up VDC/TCS, but I just went with the safe route not to mess up the speedo or anything..etc...
on
I went with 225/55/17 all around on stock Z 17" rims. The car looks like stock but the front is actually a little higher which is probably better for snowy conditions. Do this option it works well and you can rotate front to back.
on
Originally Posted by clemlover15
save the money and the car store it!!
