best tire size ?
Old Jul 23, 2008 | 07:24 PM
xtcz's Avatar
xtcz
Default best tire size ?
Hey guys .. can you guys chime in on the "best" tire size for the new set up?
- 19 - 9.5F and 10.5R
Most likely wont drop the Z this year .. so im thinking 275 in the rear .. but not sure .. 275/40? I dunno.
I dont want to roll fenders so what sizes do you guys think?
thx
Old Jul 23, 2008 | 07:36 PM
noodleman's Avatar
noodleman
i think the best choice for now is 275/35/19. Most of us with aftermarket rims that aren't FI'ed are running that size.
fronts you have an option between 245/35/19 and 255/35/19. I've ran both, and personally like 255/35/19 for the turn in. the grip feels pretty good!
with 10.5+24 and 275/35/19 tires, you're pretty safe and won't need a roll.
Old Jul 23, 2008 | 07:38 PM
eltness350's Avatar
eltness350
The Untouchable
+1...even though if u go f1 u can easily fit a 315 on it....with a roll
Old Jul 23, 2008 | 07:40 PM
fithamoto's Avatar
fithamoto
Sleeps in 350Z
+1 ^^^
I would run 275/35/19's rear & 255/35/19's in the front.
Finding those sizes in 40's might be hard.
Old Jul 23, 2008 | 07:43 PM
xtcz's Avatar
xtcz
Thats exactly what i was thinkin . i just needed that confirmation.
I didnt think of the 255F though...hmmm are you running that now ? That may be an option. I was thnking 245 b/c I was afraid of anything bigger would be rubbin with a 9.5F +17
My offest are 17/24
I went to a tire shop today and they were saying go 40 around ..
Old Jul 23, 2008 | 08:01 PM
noodleman's Avatar
noodleman
what are you stock tire sizes? mine were 245/45/18 for the rears, and 275/35/19 was the closes match in terms of overall diameter.
you can play with your overall diameters here:
http://www.1010tires.com/tiresizecalculator.asp
What was your tire shop's reasoning for going 40 profile?
Old Jul 23, 2008 | 08:11 PM
xtcz's Avatar
xtcz
stocker were
225/45 8 (front) and 245/45 18 (rear)
and it wasnt MY tire place ... ive just been calling for prices to see what i can find . they said this wil be closest to oem size
Old Jul 23, 2008 | 08:40 PM
noodleman's Avatar
noodleman
so the same as mine.
here are the comparisons...275/40/19 is way off. whatever tire place it was, they're probably lying cause that's what they have in stock and they're trying to get rid of it.
Stock Tire - 245/45R18 Tire 1 - 275/35R19 Tire 2 - 275/40R19
(S)Overall Diameter: 26.68 in 677.67 mm
(1)Overall Diameter: 26.57 in 674.87 mm
(2)Overall Diameter: 27.66 in 702.56 mm
(S)Sidewall Height: 4.34 in 110.23 mm
(1)Sidewall Height: 3.78 in 96.012 mm
(2)Sidewall Height: 4.33 in 109.98 mm
(S)Radius: 13.34 in 338.83 mm
(1)Radius: 13.28 in 337.31 mm
(2)Radius: 13.83 in 351.28 mm
(S)Circumference: 83.81 in 2128.7 mm
(1)Circumference: 83.47 in 2120.1 mm
(2)Circumference: 86.89 in 2207.0 mm
(S)Revs per Mile: 779.6
(1)Revs per Mile: 782.8
(2)Revs per Mile: 751.9
(S)Actual Speed: 60 mph 100 km/h
(1)Speedometer1: 60.2 mph 100. km/h
(2)Speedometer1: 57.8 mph 96.4 km/h
(S)Speedometer Difference: -
(1)Speedometer Difference: 0.410% too fast
(2)Speedometer Difference: 3.684% too slow
(S)Diameter Difference: -
(1)Diameter Difference: 0.42%
(2)Diameter Difference: 3.55%
Old Jul 23, 2008 | 08:42 PM
noodleman's Avatar
noodleman
play the the tire sizes on the link i posted, you can see for yourself. You can try and match the fronts if you want with 245/35/19 and 255/35/19.
Old Jul 23, 2008 | 10:48 PM
mikhe's Avatar
mikhe
you can try 275/30/19, 275/35/19. I ran that and it was pretty good. Or 265/35/19 in front.
Old Jul 24, 2008 | 02:50 AM
2TH PWR's Avatar
2TH PWR
As mentioned.
245-255/35/19 and 275-285/35/19.
Since you will have 9.5's in the front and 10.5's in the back I'd lean toward 255/ 285 myself. That was Strife's setup.
I have 8.5's in the front and 9.5's in the back and I have 245/35/19 and 275/35/19.
Whoever said 40 is WAY out to lunch.
Old Jul 24, 2008 | 03:55 AM
Reality350's Avatar
Reality350
My offest are 17/24
stocker were
Just call up one of the reputable shops that most of use and you should not have any issues..
Old Jul 24, 2008 | 06:02 AM
rzua5's Avatar
rzua5
Yep I am running 275F/R as well...best setup so far, give the Z a very neutral feeling.
Old Jul 24, 2008 | 06:04 AM
Strife350z's Avatar
Strife350z
Originally Posted by 2TH PWR
As mentioned.
Yea, I ran 255 and 285 f/r Sportcontact 2's... would highly recommend this setup. 275/35/19 on a 10.5" rear may look too stretched.
Keep in mind that section widths vary from manufacturer to manufacturer as well, even for the same published tire size. So a 285/35/19 from one manufacturer may end up being the same width (i.e. provide the same contact patch) as a 275/35/19 from another. Take a look at the published specs before buying.
