Less weight = more power; Have you lightened your Z?
#221
when i removed the spare tire, i found the car's handling very different. it was so easy to spin out and fish tail on a straight line heheh. however, the care did feel quicker..
so the question is, although the car does feel peppier when losing some weight, shouldnt you lose it in the right areas so as to not throw off the balance of the car?
#222
15 f125
on
Get an alignment. 1/4in. toe in on the back will fix that problem right up.
Mass weight loss under optimum cirumstance should be accompanied by an adjustable suspension so you can tune for the weight loss. I cannot run such a suspension and also have very limited means of reducing weight. But I have dropped 150 lbs out of the trunk and with an alignment I was able to tune the car to be very neutral for auto-X. If I had an adjustable suspension I could just lower the back a little to balance the weight out but I don't.
#224
#225
Out of hiatus
Back from the dead. I got my z weighed with 1/2 a tank and it came in at 3049 pounds. Not bad considering I have a roll bar with padding, 14" rotors front and rear, and a nitrous kit I should be under 3K in a few months when I get a Ti exhaust and remove the factory side mirrors, front speakers, and passenger air bag.
Keep this thread alive
#228
Out of hiatus
Originally Posted by 2003z
track brake calipers weigh much less than standard ones. the rotors weigh a little more.
My track Z weighs in at 2350 with 1/2 tank of fuel and driver, but its a 73
#230
Engineers from Novidem, a supercharger company in Germany drilled lot´s of holes in the front metal-bumper (behind the front bumper) which looks like a swiss cheese now. Anyway, 1,5 kg (!!!) less. This car is mainly used for Track use (Strosek 350Z-R (www.strosek.de).
Greets
Marc
Greets
Marc
#231
Out of hiatus
Greets
Marc
Greets
Marc
#234
on
#235
The Enkeis with race tire weigh 40lbs front 41lbs rear.
350Z Wheels Standard 17" Alum Alloy
F-17x7.5 + Bridgestone RE040 225/50R17
23.259lbs + 28lbs = 51.259lbs x 2 = 102.518lbs
R-17x8 + Bridgestone RE040 225/50R17
24.140lbs + 29lbs = 53.14lbs x 2 = 106.28lbs
102.518lbs(F) + 106.28lbs(R) = 208.798lbs
208.798lbs - 162lbs =46.798lbs
Not calling you a liar b/c I haven't weighed the stock wheels myself...47lbs is still nothing to sneeze at, just want to make sure our numbers are accurate here. Your numbers would indicate the stock 17' wheel/tire combo weighs an average of 60.5 lbs/ea.! Is that right?
b.t.w. wheel weights are from here and tire weights are from here.
#236
the burninator
removing the power steering is tempting
get like 8 more whp, lose 20 lbs up front, 1 less thing to overheat, better steering feel at speed, etc
but I'm not so sure about daily driven. It might get annoying as hell
might be worthwhile if the car has some huge weigh savings since the less it weighs, the better the steering will feel
#239
Originally Posted by sentry65
I'm kinda curious about relocating the battery to the rear of the car for the sake of better balance and rear traction.
I haven't heard of anyone doing it yet. I know it'll ultimately weigh the car down more overall, but balance and rear grip would improve
