MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine & Drivetrain (https://my350z.com/forum/engine-and-drivetrain-50/)
-   -   is it worth it to do the crank pulley while i'm at it? (https://my350z.com/forum/engine-and-drivetrain/111208-is-it-worth-it-to-do-the-crank-pulley-while-im-at-it.html)
sponsorsthisway Feb 21, 2005 04:46 AM
My JWT clutch and flywheel is on the way and when Crawford calls to say the plenums are going out i'll be getting the plenum, STB and the cats. I was also thinking of doing the crank pulley or the pulley set as well. Do you all think it would improve my mods i'm getting in noticably or would it not matter? Thanks!
Zivman Feb 21, 2005 05:38 AM
Re: is it worth it to do the crank pulley while i'm at it?
86 the cats and get true test pipes. and yes, the pulley would make a difference - go for it.
sponsorsthisway Feb 21, 2005 06:18 AM
How do they compare to the crawford cats?
thawk408 Feb 21, 2005 06:55 AM
Test pipes will give you rasp most likely. I would stick with the crawford cats. Good sound and power, without sounded annoying.
mofoz Feb 21, 2005 07:06 AM
You could always do resonated test pipes. I have heard good things about the kinetix pipes. No rasp either. The crank pulley will make a difference. Go for it.
Zivman Feb 21, 2005 07:54 AM
I have labree resonated testpipes and there is no rasp. They are cheaper than HFCs. IMO, go with test pipes or leave the stock cats in place. $500 for cats is just crazy if you aske me.
FairladyZ Feb 21, 2005 08:39 AM
me too
zachcrosen Feb 21, 2005 08:43 AM
$95 resonated test pipes off ebay. They are made by Megan Racing. I have heard there is some rasp but definitely less than without resonaters. There is a thread about them floating around here somewhere. I ordered mine yesterday. I will have some Helix test pipes for sale here soon. :D
Zach
kosmic Feb 21, 2005 09:23 AM
How much nastier (if at all) does your exhaust smell with just test pipes vs with the stock cats or vs high flow cats? Not a flame, I'm just curious.
Zivman Feb 21, 2005 10:36 AM
To be honest, I really don't notice a difference. The car may be a bit more smelly upon start up, but nothing really that bad. If the car is running properly, you shouldn't really have a bad smell.
teh215 Feb 21, 2005 01:49 PM
+1
03daytonablue Feb 21, 2005 09:51 PM
Yes, do the UR crank pulley it's one of the best mod's you can do for under $200.00 You will gain about 5-9 HP&TQ through out the entire powerband!
Jason@Performance Feb 21, 2005 10:00 PM
performance different between test pipes and high flow cats is soo minimal especially when you use good high flow cats...
i would do high flows and the crank pulley....
the difference in sound minus a horse power is worth not getting the headache...
sponsorsthisway Feb 22, 2005 07:29 AM
Yea, Crawford called me last night. My plenum, STB and cats are going out by the end of this week. Unfortunately, they're going to school and i'm on Spring Break all next week so i'll be home. Gonna have to wait awhile to get my stuff and then have it all installed. This is gonna take some time and i'm not a very patient person when it comes to staring at parts that should be going on my car lol. But yea, i'll be getting the crank pulley at the minimum. Is the whole set worth it? I've read it doesn't really matter.
sponsorsthisway Feb 22, 2005 07:44 AM
BTW, with these mods on the way and my current, does anyone have any idea as to what kind of hp i'll be around? ALso, will I be running lean? I'll probably need to get it reflashed but if i do the cams after this stuff i should do that before the reflash, right?
Gators2001 Feb 22, 2005 08:50 PM
How do you like ur Pioneer N1?
What negatives do see in it?
Im thinking of throwing one of those puppies in a couple of weeks.
copba1t Feb 23, 2005 12:32 AM
I had the Megan test pipes on, and although I could not detect much inside the car, they stank something awful out the a$$ end, it was a dead give-away and not worth the risk here in CA. So I switched to the new Helix cats and am very happy with them, smell no worse than stock with about the same perf as test pipes. I figure I spent $30k+ on the car I can afford $450 for some proper cats!
mystik_350z Feb 23, 2005 10:36 AM
pulleys aren't really a performance adder, its just squeezing out more performance from what you already have.
if you lighten you're crank, it will rotate quicker, hence outputing more power. sounds great right?
well all motors are harmonically balanced, meaning that each pulley, rod, piston, bolt, bearing, etc. is wieghed and balanced so that every time the crank turns, it will not cause stress on any of the other parts.
if you lighten the pulleys, than you throw off the wieght, and by doing that you cause stress on the other parts, whether it be the bolts, rod bearings, or pistons. but at that rate the crank revolves, it doesn't take long for something to go wrong. thats why you see when people build motors and build the bottom end, they have it blue printed and balanced so they dont throw a rod bearing or something 2 months down the road.
pulleys will feel like a great investment for the time being, but if you are planning on keeping the car for a while, i might stay away from them. this is just my advice to someone looking into a pulley set.
copba1t Feb 24, 2005 02:39 AM
This has been discussed over and over and over. If anyone is trying to decide whether to go with a pulley or not, please do a search and read through the HUNDREDS of posts with all the arguments anyone could ever make on the subject.
mystik_350z Feb 24, 2005 07:42 AM
im fairly new on this board, comming from the MR2 world. so please don't shoot me.
