MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine & Drivetrain (https://my350z.com/forum/engine-and-drivetrain-50/)
-   -   How's your shift into first from neutral? (https://my350z.com/forum/engine-and-drivetrain/152109-hows-your-shift-into-first-from-neutral.html)
Z BOY Nov 6, 2005 12:55 AM
i notice mine is requiring a lot of effort lately to go from neutral to first when i'm sitting at a stoplight. i have a brand new jwt clutch, too.
Barzten1 Nov 6, 2005 01:57 AM
I've been recently having an issue with this also.
Z BOY Nov 6, 2005 02:00 AM
could it be our jwt clutch?
undrgnd Nov 6, 2005 03:23 AM
mine NEVER went into 1st easily unless i've been completely stopped. the tranny seems to behave correctly in every other way. after i figured that out, i simply don't use 1st unless i'm coming from a dead stop. you apparently have something quite the opposite, which may indicate anything from the jwt clutch to synchro problems(?)
Z BOY Nov 6, 2005 10:59 AM
notice i said "sitting at a stoplight"? i never shift into first while moving. fortunately, my dealer installed my clutch, so if it gets worse, its on them.
formulaZ Nov 6, 2005 11:08 AM
mine is doing this as well. i have the nismo flywheel and clutch. just noticed it about a month ago. maybe cold weather?
illZ Nov 6, 2005 11:22 AM
doubt it's clutch related.. more like tranny or fluid being cooled.
cessna Nov 6, 2005 11:29 AM
Good point!:)
undrgnd Nov 6, 2005 11:41 AM
i did notice. did you notice i said "you apparently have something quite the opposite"?
Z BOY Nov 6, 2005 12:53 PM
i also notice if i blip the throttle, it seems to shift into first more easily. also, it doesn't seem to be internal or ambient temp related.
Jokestrap Nov 6, 2005 01:10 PM
Sometimes I have to slap it into second pretty hard, but not first.
350Zenophile Nov 7, 2005 05:20 AM
I seem to be blipping more and more to ensure a smooth shift...definitely helps the synchros out. I find it hard to believe we have triple cones on 2nd sometimes.
steakpinoy Nov 7, 2005 06:18 AM
Hmm that sounds strange. I have the JWT flywheel/clutch combo and the 1st-neutral shifts at a stoplight are fine with me.
bryants95240sx Nov 7, 2005 06:50 AM
Could be the cold. Does it do it once the car is warm? What kind of gear oil are you using in the tranny?
Z BOY Nov 7, 2005 12:03 PM
its always been harder to shift when cold, but lately its just the shift to first from neutral well after things have warmed up. i have been using factory gear oil.
