Basic Definition of Non-Revup vs. Revup
First, my apologies upfront if this is somewhere in the forums. Ive been searching for 30 minutes and not having much luck.
Can someone point me to a thread or post of how you know if your engine is a rev-up vs. non rev-up. Obviously it is important for the plenum discussion and best decision on potential upgrade, so want to get it right the first time. :confused: :confused: Thanks in advance and again, sorry for asking if it is already out here, somewhere. Mike D. Houston '04 Redline ZR, 20,000 mi, Fujita Intake, APEXi Voltage / Ground Kit |
Can someone point me to a thread or post of how you know if your engine is a rev-up vs. non rev-up. Obviously it is important for the plenum discussion and best decision on potential upgrade, so want to get it right the first time. :confused: :confused: Thanks in advance and again, sorry for asking if it is already out here, somewhere. Mike D. Houston '04 Redline ZR, 20,000 mi, Fujita Intake, APEXi Voltage / Ground Kit It's pretty simple. REVUP motors have different heads, intake manifold, connecting rod bolts. Redline is at 7k, and they have both intake and exhaust cam advancing. |
Non rev up is when your not on the gas and rev up is when your on the gas.
Wow, i thouhgt it was only the Plenum and the ECU that were different. That's alot of stuff to only have a few more HP and less tourque then the non-rev up motors. |
Yup. The REVUP's aren't just 13 more hp, they also have more potential with stock block plus more tuning capabilities because you can tune for both intake and exhaust cams. |
the answer to ur question is....03-05 Z's have the non-rev up unless u have an 05 35th anniversary they come with revups. the 06-07's all come with the revup motor.
07s do not have the revup motor, they have the hr. Just a slight bit of difference btw the two.
excuse me...my mistake i thought 07's did i did not kno that
LMFAOOOOOOOO |
Standard > Rev-up :)
It was a joke, well partly. Down the 1/4 standard > revup. Top of 4th and up, the Revup shines though.
