swap valve spring without pulling the motor
Old Jun 5, 2007 | 02:58 AM
bleunetizen's Avatar
bleunetizen
Default swap valve spring without pulling the motor
what is the usual method of doing this?
I read several threads and some people were saying that they were using special valve spring compressor either purchased or made their own.
what kind of compressor is it? the usual ones need the heads off the engine..
Old Jun 7, 2007 | 09:37 AM
DaveFunction2ND's Avatar
DaveFunction2ND
You should use this tool. It is the easiest to use. Other styles are much more expensive and require you to manualy position the retainers one at a time which can become tedious and almost impossible to do by yourself.
http://buy1.snapon.com/catalog/item....re&dir=catalog
Be sure to use compressed air (an adaptor from a compression test kit works best) to hold the valves up in the head or they will fall down into the cylinder.
Old Jun 7, 2007 | 10:38 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
+1...that is the one we use.
Fixxxercask
Nov 9, 2015 11:10 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
