Project ARC..Engine bay build in progress..
Old Aug 7, 2007 | 09:10 AM
  #101
VO...'s Avatar
VO...
Administrator
Default Teaser Pics... Look What Fed Ex Just Delivered
I try to get this installed tonight. I'm having vaccum issues with the PCV line. I have to get to that first, then I'll get to the catch can and take pics after I'm done...
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2610.jpg   Project ARC..Engine bay build in progress..-imgp2611.jpg   Project ARC..Engine bay build in progress..-imgp2612.jpg   Project ARC..Engine bay build in progress..-imgp2613.jpg
Old Aug 7, 2007 | 09:13 AM
  #102
VO...'s Avatar
VO...
Administrator
Originally Posted by Resolute
Yeah, on most coolers the lines run into the top of the cooler end caps, perpendicular to the cooling rows. This allows air to escape the system. On yours, they run straight into the center of the end caps, parallel to the cooling rows. It sounds like you didn't prime or fill the cooler and lines prior to start-up, so I could see some air trapped in the cooler ends. That would cause some extra sound for sure if that is the case.
Will
You are correct. I didn't prime the cooler. I wasn't aware this had to be done. What would you suggest to rectify this? Also, what are the negative impacts of not removing the trapped air?
Old Aug 7, 2007 | 09:23 AM
  #103
Resolute's Avatar
Resolute
Honestly, I wouldn't worry about it. It would be a little noisier, but I don't see it being a huge issue.
Catch can looks nice. Man, that stuff is pricey, though. I can't wait to see pics of your car with the modified front end.
Will
Old Aug 7, 2007 | 09:38 AM
  #104
VO...'s Avatar
VO...
Administrator
Will
Thanks for the compliments. I stickly show this vehicle and didn't want to go FI, so I figured an ARC build would be the only way to compete with the FI guys(point wise) at the shows.
As far as the trapped air, perhaps it will release upon my next oil change. we'll see.
Val
Old Aug 7, 2007 | 10:43 AM
  #105
DelayedZ's Avatar
DelayedZ
Very professional very nice build, I like!
Old Aug 7, 2007 | 10:46 AM
  #106
VO...'s Avatar
VO...
Administrator
Thank you...
Old Aug 7, 2007 | 11:14 AM
  #107
redsoxfan184524's Avatar
redsoxfan184524
Nts Nts Nts Nts
damn vo...nice looking project you have on your hands...good luck with the rest of it
Old Aug 7, 2007 | 11:19 AM
  #108
Nexx's Avatar
Nexx
arc oil cooler and arc strut bar or F/I
Old Aug 7, 2007 | 11:35 AM
  #109
VO...'s Avatar
VO...
Administrator
Thanx man...
  #110
VO...'s Avatar
VO...
Administrator
Stuck between a rock and a hard place...
Old Aug 8, 2007 | 07:11 AM
  #111
VO...'s Avatar
VO...
Administrator
Default Catch can installed...
Last night's job wasn't too difficult. As usual, the instructions had bad Engrish but were still better than the instructions for the oil cooler. After laying down drop clothes I began the first step to installation. You have to remove the intake pipe and hose that connects to the bottom of the intake pipe. The other end of the hose connects to a fitting under the throttle body. Here's a few pics.
The yellow circles indicate where the stock hose was connected to. I've also included a picture of that hose. These 2 fittings are where the ARC tubing will connect.
Notice I removed the stock filter box also. It makes the job alot easier.
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2615.jpg   Project ARC..Engine bay build in progress..-imgp2614.jpg   Project ARC..Engine bay build in progress..-imgp2617.jpg   Project ARC..Engine bay build in progress..-imgp2616.jpg
Old Aug 8, 2007 | 07:16 AM
  #112
VO...'s Avatar
VO...
Administrator
Here's what the it looks like after the 2 ARC hoses are attached. Notice the hose that attaches to the fitting under the throttle body gets wrapped around the backside of the plenum.
Another thing to be aware of, is when routing the hose that attaches to the instake pipe. It has to make a sharp curve in order to get to the front of the block. I've included pics to illustrate how I made my bend. Make sure not to crimp this hose...
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2618.jpg   Project ARC..Engine bay build in progress..-imgp2621.jpg   Project ARC..Engine bay build in progress..-imgp2619.jpg   Project ARC..Engine bay build in progress..-imgp2620.jpg
Old Aug 8, 2007 | 07:26 AM
  #113
VO...'s Avatar
VO...
Administrator
The last hose that gets attached to the block is the PCV hose.
After removing the engine cover, you remove the stock hose that feeds the PCV valve to the intake manifold. The smallest ARC hose attaches to the PCV valve, then you cap off the intake manifold fitting with the nipple provided in the ARC package.
By the way, this is where I had my vaccumm leak as previously stated. The car is idling smooth now.
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2624.jpg   Project ARC..Engine bay build in progress..-imgp2626.jpg   Project ARC..Engine bay build in progress..-imgp2625.jpg
Old Aug 8, 2007 | 07:32 AM
  #114
VO...'s Avatar
VO...
Administrator
After all the hoses are attached you can mount the catch can then re-install the intake tube in reverse order you took it out.
The catch can is attached to the radiator with one screw and a cip on the bottom of the can, which you can't see in the pic. It's a really snug fit.
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2622.jpg   Project ARC..Engine bay build in progress..-imgp2623.jpg
Old Aug 8, 2007 | 07:33 AM
  #115
Vertex350's Avatar
Vertex350
Bling ballin!
Old Aug 8, 2007 | 07:35 AM
  #116
VO...'s Avatar
VO...
Administrator
After alittle metal polish, the engine cover was ready to go back on. I didn't reattach the strut bar because the new one should arrive today. I'll install it tonight or tommorow and post new pics.
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2629.jpg   Project ARC..Engine bay build in progress..-imgp2630.jpg   Project ARC..Engine bay build in progress..-imgp2631.jpg
Old Aug 8, 2007 | 07:36 AM
  #117
VO...'s Avatar
VO...
Administrator
Can someone tell me where to get some of this high temp tape that goes on the under side of the engine cover? The original one is wearing out bad..
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2627.jpg   Project ARC..Engine bay build in progress..-imgp2628.jpg
Old Aug 8, 2007 | 07:37 AM
  #118
VO...'s Avatar
VO...
Administrator
Originally Posted by Vertex350
Bling ballin!
Old Aug 8, 2007 | 11:05 AM
  #119
VO...'s Avatar
VO...
Administrator
Talking Update: The Holy Grail of Strut Bars Has Arrived...
After a long 5 month wait, this baby has made it's way across the Pacific Ocean into my little hands. Marty @ Injected Performance is the man! He's responsible for many of my parts over the years. He's always prompt and stays on top of things, making sure to give me curtesy calls when my parts arrive. I should have this thing installed in no time tonight since the OEM strut bar has already been removed. I'll snap more pics after installation, probably tomorrow night.
Attached Thumbnails Project ARC..Engine bay build in progress..-imgp2633.jpg   Project ARC..Engine bay build in progress..-imgp2636.jpg   Project ARC..Engine bay build in progress..-imgp2634.jpg   Project ARC..Engine bay build in progress..-imgp2635.jpg
Old Aug 8, 2007 | 12:07 PM
  #120
Biochem7's Avatar
Biochem7
Regular
So for the catch can, the two ports for the valve cover (driver side and passenger side) get attached to the INLET port of the catch can and then the intake tube is attached to the single OUTLET port of the catch can?
