MY350Z.COM - Nissan 350Z and 370Z Forum Discussion (https://my350z.com/forum/)
-   Engine & Drivetrain (https://my350z.com/forum/engine-and-drivetrain-50/)
-   -   I'm having Clutch/Drivetrain Issues, unknown...please help with input or past exp. (https://my350z.com/forum/engine-and-drivetrain/426777-im-having-clutch-drivetrain-issues-unknown-please-help-with-input-or-past-exp.html)
ZeezCustomz Apr 3, 2009 12:53 PM
Ok, here is the deal.. I have an 03', 6 speed (original/factory) 42,xxx miles with a stock clutch and flywheel. I am noticing this problem more often when the car is cold but it has happened at all times of the day so I am convinced this has nothing to do with temperature. When I go to shift into first, clutch in at a stop (fully depressed), the car wants to "bump" forward. Its not wanting to move the car significantly but enough to hear a clunk. Now this is without me applying any rpm above idle and not moving the clutch. It only happens at the first spit second of going into gear. After it happens once, it wont do it again unless you move to nuetral, let the clutch go....press in the clutch and move into gear again..."reset". Something is telling me that my clutch is not fully disengauged when this happens...yet it makes no sense to me. The clutch is not slipping either. Anyone had this problem?...remedy? Please any experiences may help, thanks.
ZeezCustomz Apr 5, 2009 11:09 AM
Bump for some needed help!
ZeezCustomz Apr 9, 2009 12:31 PM
bump :(
tiguy99 Apr 9, 2009 02:01 PM
Is there a way you can have someone ride with you to help you record a quick video clip of what's happening?
ZeezCustomz Apr 10, 2009 09:45 AM
I could but the issue is very subtle, I will try placing a camera down by the diff and see if I can't pick it up there.
zettahertz Apr 11, 2009 11:29 AM
hmm, i think mine does that too but haven't thought much about it.
Sharif@Forged Apr 12, 2009 07:21 AM
The first time you engage first, there will be some resistance as the sychros do their job. If you keep the clutch pedal depressed, but goto neutral, and the quickly to first again, it's a much smoother engagement.
What you are describing, sounds like you are picking up some very very subtle changes in the operation of your synchros. I really would no worry about this at all. Might try switch to Motul 75-90 Gear 300 which is the best gear oil for our trans.
davidv Apr 12, 2009 07:40 AM
Easy on the bump.
Not sure what you are talking about. Minor resistant shifting when the car is stopped? No big deal. Sometimes I have a habit of going second to first gear then second to first gear again if the shift feels “funny.” I just do it twice.
ZeezCustomz Apr 16, 2009 12:20 PM
Thanks for the great response, this puts me at ease. I already bought the Royal Purple max gear 75-90, would you recommend using the RP?
str8dum1 May 7, 2009 09:14 PM
as this is a fairly new post, is this still the consenus. I need to do a tranny flush and get some new tranny fluid.
My car has the same issue. hard to get into 1st from neutral but gets easier if you go 1st, 2nd and back to 1st.
2boosted4u May 7, 2009 09:35 PM
Still got the stock tranny? I had mine replaced at 44XXX miles cause 2nd went bad and first was just sloppy...now got 30XXX on the new tranny and its chill. But if that's all the problems ur haven I wouldn't worry
