Oil help!!!
Old Jun 29, 2009 | 06:29 AM
Z3303's Avatar
Z3303
Default Oil help!!!
I own a 2003 350z 6mt 63K. I am consuming 1qt/500mi and I dont know why oil is Burning? I am showing some signs of smoke only at full throttle in the upper RPM's. My coolant is still bright green no issues there. I just dont get it, my car runs perfect! any help would be much appriciated!!!
Old Jun 29, 2009 | 06:31 AM
rcdash's Avatar
rcdash
You can try adding a catch can (search for those keywords) and try replacing your PCV valve - $20 or less, but you need a big @ss socket to get it off (I think 21 mm but not sure)
Old Jun 29, 2009 | 06:37 AM
Z3303's Avatar
Z3303
Had a catch can(husky air style) filled up about half 40% of the way after 250 Miles. Nissan dealer didnt stock pcv valves said they never replaced one yet on a car.
"Dosent really need to be done" He said
Old Jun 29, 2009 | 07:08 AM
Oil is getting in the combustion chamber where it should not be. You can do a compression and leak down test for diagnostics.
Old Jun 29, 2009 | 12:21 PM
davidmcc's Avatar
davidmcc
You're burning oil which means you have at least one or more faulty rings.
time for a rebuild
Old Jun 29, 2009 | 01:36 PM
Z3303's Avatar
Z3303
If the rings were shot wouldn't it smoke all the time? Or even Run like ****? The car runs perect
Old Jun 29, 2009 | 01:56 PM
davidmcc's Avatar
davidmcc
Depends on how bad they are, all the 06's with oil consumption issues still ran fine.
like it's been mentioned a compression test is the best way to know for sure.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Stevo Z
Oct 3, 2015 09:14 PM
